Originally Posted by Ogren I do not have another monitor to hook up my laptop to sorry. Other then that I've looked everywhere on the receiver and i see nothing that allows HMDI sound to be turned on. Everything seems like it's turned on. The cable box is set to HDMI out until I hooked up the RCA cables to actually get sound. |
Does your laptop have a dvi/vga connector on it? It should. Use that type of cable to hook up to your tv and see if you get video.
Also try the HDMI cable but see if you can boot into Safe Mode.
