Old January 25, 2012, 03:36 PM
ultraman7k's Avatar
Default 4th monitor question
Hey guys,
currently running an eyefinity set up that runs at 5760x1080. Obviously all monitors are running at 1920x1080. Thinking of adding a 1680x1050 monitor on a wall mount for IM, movies, gauges etc.
My question is, if I add a 4th monitor that is NOT 1080p, will it skew the resolution I have now and force eyefinity, into going into some "best fit" resolution?
Thanks.
Old February 7, 2012, 12:50 PM
NightRain's Avatar
No you won't need to scale anything. Just use display groups, one for the eyefinity group at 5760x1080 and the other for 1680x1050. This can easily be configured in CCC.
Lian Li PC-V1010B : Dell U3011 30" LCD : Dell U2311 23" LCD : Asus P6T Deluxe X58 : Intel i7 920 @ 3.5GHz : OCZ DDR3 12GB @ 1483MHz 8-8-8-24 : Noctua NH-U12P : 2x MSI 6970 Lightning CF : Auzentech X-Fi Forte 7.1 : 2x Samsung DVD-RW : Samsung DVD-ROM : OCZ Synapse 64GB Cache SSD : WD 1.5TB Black HDD : 2x WD 1TB Black HDDs : Corsair HX1000W : Cyborg R.A.T. 9 : Razer BW Ultimate Keyboard : Energy C-200 /w Yamaha RX-V667 AVR : Sennheiser HD555 Headphones : APC UPS XS 1200 : WIN 7 ULT 64
Old February 8, 2012, 10:05 AM
Yep this is all you need to do, when you first plug the monitor in it might change your other monitors resolution but yo can just manually set that back and create groups.
wireless monitor question darkeyzs Display Units 3 October 5, 2011 09:01 PM
Monitor arm question Kilauea Display Units 4 May 21, 2010 11:10 AM
Another 2 Monitor Question Chromey Display Units 4 April 19, 2010 02:13 PM
anyone who using hw monitor question gingerbee Overclocking, Tweaking and Benchmarking 4 March 24, 2009 09:44 AM
Another LCD TV as monitor question MpG Display Units 6 August 14, 2008 10:29 PM
