Old January 26, 2012, 06:18 AM
Originally Posted by r0k0 View Post
Sorry, 1 screen setup, HDMI was plugged, took it out to put the DVI because theirs no benefit since i cant use HDCP
currently on DVI, even if i put the HDMI back, gives me black screen anyways
currently in safe mode.. anything i can do / change for it to boot up normally ?
Uninstall video drivers and start again.
Old January 26, 2012, 09:44 AM
r0k0's Avatar
did it, booted in windows, installed new driver... loaded in windows black screen again
Main Rig
Intel Core i5 2500K - 5.0
Asus Maximus Gene-Z / Gene 3
4x 4GB Corsair Vengence DDR3-1600
AMD Radeon HD 6990 4GB 880 / 1300
Crosair 600T White / Enermax Revolution 920W
A-DATA 120GB SATA3 SSD / Seagates 1TB Spare SATA3
Canadian Eh ?
Old January 26, 2012, 10:20 AM
Tried another DVI port?
Move GPU to second slot?
Old January 26, 2012, 12:47 PM
r0k0's Avatar
i can try in the other DVI but my motherboard says it will fail to boot in a single card setup it isnt in the first pcie slot
Main Rig
Canadian Eh ?
Old January 26, 2012, 03:27 PM
r0k0's Avatar
ok well plugged the pc in the living room, running on my 42" LCD at 1366x768 it shows Windows... so im guessing something is wrong with the 1920x1080 resolution ?
any input on what could go wrong ?
Main Rig
Canadian Eh ?
How to fix Ati Radeon Screen Problem I_need_a_new_RIG Video Cards 0 October 9, 2011 06:12 AM
iMac Screen problem p3t3rson Mac 5 April 13, 2011 06:17 PM
ATI Catalyst 10.11 Problem (Black/Green Screen) siklee Video Cards 4 December 10, 2010 06:46 AM
Screen problem GTX 470 + LG W2252TQ prysk Troubleshooting 3 November 14, 2010 08:07 AM
Vista/XP black screen problem r00tman Video Cards 12 October 3, 2007 07:37 PM
