Old January 11, 2012, 07:43 PM
Default Wall mount advice
Hello,
My gf would like to have a wall mount for a her VW266H (25.5in and about 18 pounds) monitor, she would like to have an arm to pull it towards her and to be able to turn it (I believe its pan) at least 90 degrees.
I have looked at Monoprice and while I love the prices, I can't seem to find what I would require. I believe this Ergotron MX wall mount LCD arm would fit the bill, but first I'd like some input.
Thanks,
Old January 12, 2012, 01:40 PM
I don't know if it's the right part of the forum but hopefully I will get some advice, planning to order tonight.
Old January 12, 2012, 02:57 PM
KaptCrunch's Avatar
take a pic of the wall where your going to mount ?
The sleek MX LCD Arm accommodates mid-sized displays and all-in-one computers weighing up to 30 lbs (13.6 kgs). for sure you have to screw in stud not drywall to mount this........if where you want it, no stud, gonna have to cut drywall and put enforcements between 2x4 stringers and tape a new picse of drywall
if brick need good lag screws
Old January 12, 2012, 03:33 PM
I can handle the mounting on a stud... but the wall mount will work for what I need and there are no other suggestions ?
Old January 12, 2012, 04:05 PM
Personally, I'd go for a desk mounted monitor arm, but Monoprice does have some wall mounts which allow rotation. I've been wanting to try some of Monoprice's offerings, but never found a good excuse yet.
For only $13.92 each when QTY 50+ purchased - Adjustable Tilting Wall Mount Bracket for LCD LED (Max 33Lbs, 13~23inch) - Silver | LCD Wall Mount Brackets
For only $17.34 each when QTY 50+ purchased - 3 Way Adjustable Tilting Wall Mount Bracket for LCD LED (Max 33Lbs, 10~25inch) - Black (No Logo) | LCD Wall Mount Brackets
Old January 12, 2012, 06:35 PM
Originally Posted by xilocient View Post
A desk mount was the first choice, but none of them work.
Wall Mounts Where to Buy? Supergrover Display Units 5 September 4, 2011 10:09 PM
top mount- bottom mount - does it make a difference? johnnyblazzwa Power Supplies 5 December 20, 2009 08:13 PM
QPI wall, any suggestions? Putz Overclocking, Tweaking and Benchmarking 8 September 16, 2009 07:25 AM
Wall-E Case Mod Evilyeti Cases 15 May 2, 2009 04:27 AM
Wall-E PC Mod Digikid Off Topic 9 April 9, 2009 03:42 PM
