Old March 6, 2008, 04:03 PM
Default need help with new AQUOS
picked up a new aquos slimline LC-32D64U it's a full 1080p 1900x native but i'm having trouble going above 1600x what gives?
Old March 6, 2008, 04:28 PM
SugarJ's Avatar
I have an Aquos 46" at home, and if I recall correctly, the DVI connection will only accept up to 1600x resolutions. If you want 1920x1200, I think you have to use the HDMI connection.
I'll check my manual when I get home to confirm.
Old March 6, 2008, 04:56 PM
Cptn Vortex's Avatar
I have one of the 32" ones, and I use a DVI to HDMI cable and it does 1920x1080 no problem. What is the issue you have? No screen?
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
12GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old March 6, 2008, 05:00 PM
3 hours later i opened the manual
PC compatibility chart tells me the max uxga is 1600x1200.
it looks great next to my old 19 inch but I was sure i could run a full desktop. I guess this is not the monitor replacement I was looking for.
what about the HDMI input? will this give me the full desktop i want
Old March 6, 2008, 05:44 PM
sure thing it was the cable.
$24 later and i'm a happy man.
the 32 is so so sweet i guess i won't get any sleep today.
Old March 6, 2008, 05:48 PM
DVI vs. HDMI shouldn't make a difference, electrically, they're the same cable, except that DVI doesn't carry sound. Nice screen though, Sharp has some beautiful hardware.
Old March 6, 2008, 06:15 PM
Yeah it's a great screen eh! I loves mine!
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
Watercooling:
Old March 6, 2008, 08:12 PM
WoW the screen fills my peripheral vision, I've never felt this level of immersion. I just had a quick COD4 session and i think i got motion sickness. nausea medicine ain't cheep ya know
BTW - this thing is 3" thick at it's widest and has a USB port. ohhh baby . . give me a week or two and i'll make give you a decent review of this thing
Old March 8, 2008, 05:44 PM
SugarJ's Avatar
It's not that the DVI cable won't carry the signal, it's Sharp's hardware that allows max resolution of 1600x on the DVI input. In order to get to 1920x1080, you must use a HDMI input on the Sharp.
Like Krixxer said, RTFM, $24 cable, problem solved. One of these days I'm going to try gaming on my 46", but it's too heavy to move easily.
