Ok here's the scoop! I've been hunting around for 18-19 inch monitors with 16x10 to 1080p resolutions to build an in expensive eyefinity setup. Mainly I don't wanna use up ALL my desktop and I wanted to do the 6 display setup too.
Couple things I don't know for sure:
6 displays means the crosshair goes into the bezel. Can the bezel be removed from LCD monitors? Can I rebuild the bezel and make it smaller? Maybe 9 monitors would do the trick? Is that even possible?
What are the 2 best choices for monitors of that size? I'd like to keep the GTG timing low as possible 2 would be great but if 5ms is all I can get than it should be fine.
TIA!
