Old November 25, 2011, 08:31 AM
fishingfanatic's Avatar
Smile One Big tv or multi monitor
I'm pretty sure about the consensus, but thought I'd ask anyway. I use a 55" LED 120hz tv, using HDMI, as my monitor. Though I've never actually seen a setup in person, I'm wondering if the multi
monitor setup is really that much better, or is it for extremists and not really. I understand this is subjective as I like my current setup, but would like to hear from the experts on this site and learn the
pros and cons of either one.
Edit: I forgot to mention my gpus, a pair of 580s in sli.
Old November 25, 2011, 12:44 PM
dandelioneater's Avatar
single screen: cheaper, run games with settings maxed out,
surround setup
: 3x the resolution, more immersive gaming experience, more expensive, needs lots of gpu horsepower, screen bezels, driver issues?
Old November 25, 2011, 10:17 PM
tvs also have some input lag that is caused by the TV encoder thingy, but the amount depends on the TV model
Facta non verba!
I <3 c0mput3r5 !
Old November 25, 2011, 10:28 PM
NI3 NI3 is offline
It depends on the games you play.
I bought 3 screens for racing games, or flight sims, and I would have a hard time playing them with a single screen. I simply love it. On the other hand, for FPS, or action games, I usually find myself playing in 1 screen anyways, as a lot of games don't support it properly.
If you only play FPS/action/RTS, it isn't really worth the trouble, for racing/flight sims there isn't a doubt, it is absolutely great.
There is also the point about desktop real estate. When I am working on things, 1 screen has information, screen 2 has documents, and screen 3 varies. Images, video, ebooks, music player. 2 screens is the minimum for me when working I find now.
Edit: 580s will have the guts to run most things.
I would like to retract my statement about it not being worth it. When I know a game supports it, I love it. I would look at some specific games you want to play, and if they have major problems, then I would avoid 3 screens for now. BF3, Skyrim, MW3 do not support it properly,
Old November 26, 2011, 08:08 AM
great_big_abyss's Avatar
I'm just wondering. Isn't SLI 580s a LOT of horsepower for 1080 resolution? You could easily get two more 55" TV's and run 3 of them at the same time. Wouldn't that be something?
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; Sapphire HD5870; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; ASUS GTX650Ti Boost; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
Old November 29, 2011, 10:25 PM
Hahah, get a 30" at 2560x1600 and you'll be amazed at how nice it looks compared to a TV. Either way, the monitors will provide you with much better quality (and you can even get 120hz monitors and not use 3D vision).
Also, multi-monitor setups are amazing for the productivity (have a movie running in one, your web browser and chat in another, a game in the 3rd, or some other crap... etc).
My suggestion: use monitor(s) over a TV screen.
Bounty for Multi Monitor Setup Advice kurisu Display Units 7 July 2, 2011 03:46 PM
Multi Monitor Span & Clone enaberif Video Cards 2 May 3, 2011 05:38 PM
Multi-Monitor Gaming Arinoth Display Units 12 November 30, 2010 10:09 AM
Crossfire Multi-monitor setup? nzorov Video Cards 4 April 16, 2010 08:33 AM
New Nvidia Drivers / SLI Multi Monitor + SLI on X58 - 180.48 probationer O/S's, Drivers & General Software 14 November 26, 2008 08:40 AM
