Old November 22, 2011, 08:35 AM
supaflyx3's Avatar
Originally Posted by PcWizTech View Post
I understand the topic says 32 inch but now im looking for 27 inch :P. I'd literally be about 1-1.5 feet from the screen. I cant stand it if the screen is too big.
I would say even at that.. 27 would be a little large :l
Old November 22, 2011, 02:29 PM
bigFOIG's Avatar
i think you'd be happy enough with a nice 24" monitor. think most monitors are wall mountable. maybe 150 for that on boxing day, and a bit more for a mount. and then you get to stay in budget! :P
Old November 23, 2011, 06:54 PM
yycraven's Avatar
What video card do you plan on using with this 27 in or 32 in LCD. Cause that can make the difference on what you want to buy.
Tags
3d ready , hd tv , monitor , mounting
