Old November 16, 2011, 10:15 PM
Default Sub $250
In your opinion which monitor would be the best for me? A 23-24" monitor under $250, used mostly for web browsing and movies. Asus ML238H ?
Thanks for the help.
Old November 17, 2011, 10:28 AM
For $250 you are getting a 1080p for sure....good for movies but I prefer 19*12 for web or anything else. Samsung B2430Hs are on for $180 at memex right now...probably the way I'd go for under $250...bit of a big bezel if you are thinking multi display but good TN screen.
