Old November 6, 2011, 01:39 AM
As Quicken points out, don't worry about burn-in.
You can get a 50" GT30 or a 55" ST30 for $1500.
The GT30 shares the exact same plasma panel and AR filter with the ST30, but adds:
- THX Mode (not as special as it sounds, especially if you end up doing any kind of calibration)
- slightly better black levels (both excellent)
- narrower bezel with a silver outer trim surround
- thinner rear cabinet and bezel
- 4 HDMI inputs (all mounted on the left side) compared to 3 on the ST30
- VGA PC Input (but limited to a 768p signal so it's fairly useless)
If I were choosing between the two, especially considering that they are at almost the same price, I'd be springing for the ST30. The 5" is a lot of extra real-estate and the increased size will have the biggest impact on viewing experience.
The cheapest retail price I can find is at Visions @ 1,498.00 until Nov. 9th. Sears has it @ 1549.99 but I'm sure they'd be happy to price-match, along with any other dealer you can find with the 55" ST30 in stock. The cheapest online I can find is Electronics For Less @ 1,427.00. You may get lucky finding a retailer willing to match that price as well.
Old November 6, 2011, 08:48 AM
Gregole's Avatar
Well I did find an ST30 on Futureshop for $999.99
Now Playing. . .
Old November 6, 2011, 12:27 PM
$500 is a nice chunk of change saved. I guess it depends whether or not that extra 5" is worth $500 to you.
Old November 6, 2011, 12:54 PM
Gregole's Avatar
Well actually I measured the width, 50 inch tv is just perfect, 55 inch is close to the edge of the stand, 60 inch has a higher chance of getting toppled when someone bumps into it.
Now Playing. . .
Old November 6, 2011, 01:18 PM
The Quicken's Avatar
Something else to consider, you will/can notice the difference between 720p & 1080p media when you go over 50". 50" is a good size IMO.
Not trying to max out your budget, but see what price that Futureshop can get you on a 50" GT30?
Old November 6, 2011, 05:48 PM
howpet's Avatar
For what I know (which isn"t much) or have read LCD or Plasma depends a lot on the ambiant light in the room it"s going to be situated. A room with say a large picture window where in the morning or afternoon a lot of light is streaming in go plasma because of the higher contrast; if this isn"t an issue LCD will be fine as long as viewing angles don"t come into play.
This is not hands on experience advice I"m offering(still watching a Samsung 32" Crt tv, every bit of 150 lbs.; It won"t die) but web research.
For an LCD look at Sharp..newest manufacturing facility in the world right now.
And a Plasma the only way to go is Panasonic...
The Samsung is going to die soon I hope.....
Old November 6, 2011, 06:27 PM
Gregole's Avatar
The GT30 costs about $1700.
Now Playing. . .
Old November 6, 2011, 06:38 PM
howpet's Avatar
You"ve got lots of time to research and investigate so make sure come boxing day the CC fresh and you"re standing at the front of the line
  #19 (permalink)
Old November 6, 2011, 07:45 PM
Then my personal suggestion would be the ST30. Be clear on your return policy as whatever you purchase you don't want to worry about exchanging it. I keep bring up exchanges because it's a good chunk of money and you want to be completely happy with your purchase.
I want the GT30 for the slightly better display/BL, extra HDMI input, THX & the aesthetics (finally a Panny that looks current gen).
I would price match futureshop and get it at Bestbuy, reason being I find retuning at Bestbuy painless where as at Futureshop I always seem to get a rough time.
  #20 (permalink)
Old November 7, 2011, 01:05 AM
Gregole's Avatar
The ST30 on bestbuy is 46 inch while 50 inch in futureshop.
Now Playing. . .
[WTB] Buying a SSD, PM me THS Buy/Sell & Trade 0 July 25, 2011 01:15 PM
Buying PS3 Nevakonaza Gaming 36 July 29, 2010 03:48 AM
GTX 480 & 470...are you buying one Wi-Fuzzy Video Cards 58 April 6, 2010 10:20 AM
Buying Games RainMaker Gaming 23 July 22, 2009 04:36 PM
[WTB] Buying List Sipek Buy/Sell & Trade 16 May 13, 2009 06:54 PM
