Old October 12, 2011, 06:48 AM
bojangles's Avatar
Default Crooked plasma panel on my new HDTV.
I just bought a Panasonic TCP46S30 plasma HDTV. Movies and games look great when at the proper distance. However, what I'm wondering is if I am eligible to exchange this TV for a new one.
It slants slighty to the right. When I'm watching something on my TV I have about a 1/4" gap at the top left in between the bezel and the panel. There is about a 1/8" gap at the bottom left. I think you can catch my drift here.
Thanks,
Eric
Old October 12, 2011, 07:25 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
That is definitely returnable.
Old October 12, 2011, 10:04 AM
JD JD is offline
I would take and print some pictures out as well to take with you in case they try to argue or don't want to plug it in.
Sounds like a QA slip-up for sure though.
Old October 12, 2011, 01:15 PM
The Quicken's Avatar
Ouch, that sucks--return ASAP.
Old October 12, 2011, 01:32 PM
bojangles's Avatar
Thanks guys. Talked to a manager over the phone. Will exchange no problem.
Can any of you recommend an HDTV in the $800-900 range? I like this Panasonic plasma, but if I can get more for my money, just let me know.
Cheers.
Old October 12, 2011, 04:51 PM
Cheers.
IMO you have the best bang for your buck as is (after you exchange).
This years panny model the St30 starts around $1200 for a 50". Maybe adjust your budget and get the current model?
Old October 13, 2011, 05:28 AM
bojangles's Avatar
I'm thinking about upgrading to the ST30. Taking it in tonight to see what else is available.
Old October 13, 2011, 09:02 AM
Bao Bao is online now
In the budget range, the Samsung D550 51 inch 1080P 3d plasma is usually $899.99... weaker blacks than panasonic, but better colours, and the 5 inch increase is huge, yes that's what she said.
The LG PZ550 inch is also in that range, but the black levels are LCD like on this model so not a good buy imo.
The 50 inch Panasonic S30 is on sale this week at Leon's for $899 as well!
lcd vs plasma gingerbee Display Units 15 October 12, 2011 06:49 AM
HD Plasma TV, Burn in or something else? dosmond Display Units 7 May 14, 2011 01:22 AM
Plasma HDTV for gaming? Full Speed Display Units 17 December 5, 2010 10:43 AM
Want to sell my plasma... crazyhorsejohnny Off Topic 4 April 30, 2009 02:59 PM
DailyTech sets up sting for crooked techsites. Babrbarossa Reviews & Articles from the Web 16 June 12, 2007 11:41 PM
