They're both great monitors, you can't go wrong with them. If you plan on doing photo editing then I highly suggest you purchase a colorimeter.
I recommend the X-Rite i1Display. It's only around $100 bucks and uses the same hardware as the Lacie Blue Eye Pro. I highly recommend you use Lacie's software (you can search for it online) as it's much better overall.
X-Rite i1Display 2 (link is non-affiliated)
If you don't really need an IPS, then any monitor would do really. There's lots of great monitors from ASUS or ViewSonic these days, for under $200. They can be very accurate color-wise if properly calibrated.
Andy H.
