Old August 1, 2011, 04:17 PM
Default any recomendations on a HD gaming moniter?
hey guys,
looking for a 1080p gaming moniter between 23"-26", i was looking at the asus ML249H and the LG W2361V-PF, any recommendations or which of the above two is better? price range = around $300,
Old August 2, 2011, 04:07 AM
10e's Avatar
10e 10e is offline
The Asus ML249H uses the AUO A-MVA panel which displays fabulous blacks, and is overall nice visually, but suffers from slow response time and blurring.
When you say HD gaming do you mean PC and console? If so what console?
Old August 2, 2011, 05:21 AM
thanks for the reply :),
console is xbox 360
Old August 2, 2011, 07:28 AM
10e's Avatar
10e 10e is offline
The Dell U2311H is also good for this, as is the NEC EA232WMI. Both should work fine with a PC and 360 and are in that price range. I think I saw the NEC running in the $275.00 range.
The NEC has W-LED backlighting so it will use less power and backlight will not degrade over time, causing brightness to reduce.
Here's a review on the NEC:
NEC EA232WMi Review
And one on the Dell:
Dell U2311H Review
Either one should be a pretty good screen for your needs.
moniter screen repair KaptCrunch Guides & How-to's 0 February 6, 2011 08:48 AM
Moniter Issue AmuseMe Troubleshooting 3 June 18, 2009 03:58 PM
is there a way to connect a laptop moniter to a PC Shadowmeph Display Units 8 April 15, 2009 11:40 AM
Would like some recomendations for good gaming/movie speakers Gameplaywarrior Audio 1 December 11, 2008 05:39 AM
Could i dual screen with a moniter & a CRT TV? Kayen Display Units 5 July 28, 2008 12:43 AM
