-   Display Units (http://www.hardwarecanucks.com/forum/display-units/)
-   -   LCD desk mounts (http://www.hardwarecanucks.com/forum/display-units/45151-lcd-desk-mounts.html)
ad5ter July 25, 2011 07:47 AM
LCD desk mounts
Anyone know where's a good place to find a dual LCD monitor stand taht will support 2 24 inch monitors? I'd prefer if it can latch on to my desk.
Squeetard July 25, 2011 08:12 AM
Ergotron is the best brand:
Ergotron Products>Desk Mounts
SKYMTL July 25, 2011 08:13 AM
Most multi monitor stands have their own base for obvious saftey reasons.
aristhrottle July 25, 2011 10:13 AM
Knoll makes a very, very good one: Knoll : KnollExtra : Sapper™ Monitor Arm Collection I'm not sure if it supports two 24"s though.
Humanscale also makes an almost-as-good one: http://www.humanscale.com/products/p...p=m8monitorarm I'm pretty sure this one supports two 24s.
Both of these have the option of clamp mount btw.
ad5ter July 25, 2011 10:42 AM
Humanscale also makes an almost-as-good one: M8 with Crossbar | Adjustable Monitor Arm from Humanscale I'm pretty sure this one supports two 24s.
These look great but holy crap expensive lol.. Thanks for all the suggestions though!
mo' power July 25, 2011 04:31 PM
You could also check ebay. A few distibutors have popped up lately and they're cheaper. Might be what you're looking for. They have single, dual, triple and quad monitor mounts.
ad5ter August 4, 2011 12:37 PM
ended up going with this sucker
For only $33.60 each when QTY 50+ purchased - 3-Way Adjustable Tilting DUAL Desk Mount Bracket for LCD LED (Max 33Lbs, 13~23inch) - Black | LCD Desk Mount Brackets
Description says fits from 13 - ~22, but my friend ordered one of these and mounted 2, 22' Samsungs with lots of adjustment room. Reviewers also mentioned that 2 24 inch monitors can be supported.
Thanks for all the help guys!
lowfat August 4, 2011 01:08 PM
I have a monoprice one. It is good for the money I paid but definitely not all that high quality. As long as I don't move the monitor around it does fine though.
grinder August 4, 2011 02:53 PM
the Ergotron products are nice. Setup a LX dual model, and Neo-Flex dual model. They work well.
moocow August 9, 2011 03:51 PM
I haven't used any of their product but you may want to look into Tyke Supply.
Review:
[Phoronix] Tyke Supply Dual LCD Monitor Stand Review
