Originally Posted by Flakk I've read all of those reviews and more. So what is it about that monitor that makes you feel it ranks above the HP?
And what about ProArt's wide color gamut? I won't be making much use of that. |
Both the Asus and Dell are nearly functionally equivalent monitors. Both are good quality and pre-calibrated for Adobe RGB and sRGB from the factory, which is a good thing.
But if you are going to be in the sRGB color space I would assume the HP probably would be the best bet taking price-performance into consideration and the fact that it is a sRGB panel from the start, and doesn't need to emulate a smaller color space.
