Old July 1, 2011, 08:03 PM
Question Bounty for Multi Monitor Setup Advice
Background
I've been doing research now for close to three months on what new monitors to buy.
I currently have a BENQ FP241W which has been great for 4 years. Over the past 2 years however the the top middle area of the display has becoming increasingly burnt-in. There is a pattern that is ALWAYS there, it looks like a cloud almost, and any image in that area left up for more then 5-10 minutes will persist for hours.
What I am looking for
I'm looking to buy two monitors in the 23.5-24 inch range with comparable latency to my FP241W. I've considered both getting two separate monitors for separate uses, but I would prefer getting two monitors that are the same, or have very similar colors.
  • Same or lower latency and input lag as my 241W
  • Preferebly one without a record of image persistence
  • Decent Color accuracy. I do a lot of design work, but I am not extremely picky when it comes to colors.
  • No preference towards Matte or Glossy screens
  • No preference towards back light type.
  • I hate over saturated colors.
  • At least one monitors must be 16:10, prefer both to be.
  • No lower resolution then 1920x1200 or 1920x1080
  • Great real world contrast ratio.
  • Decent viewing angle. I sometimes watch t.v. or play games from my couch which is about 1-15 feet away.
  • Preferably no more expensive then $600 each.
PIP, multiple inputs, speakers optional but nice.
The closest I have come to a decision is the dell U2410, but almost all the programs I use are not color space aware, and I really dislike over saturated colors. The Eizo Foris FX2431 seems perfect, but waaay to expensive. The only way I could consider buying that is if I was sure both would last 10 years.
I'd like to see both VAs and IPS panel types, as I haven't been able to decide which to get.
What I do/What I will use them for
I am a programmer, and web designer. I spend most of my time looking at, or writing text/code. I watch all of my television/movies on my computer, and spend about a minimum of 15 hours a week gaming. Overall I am using the computer 10-15 hours a day. The reason I am opting for a multi monitor setup and not one large monitor is so I can run full screen movies/apps (virtualmachines) in one of the monitors as I work.
I'm so desperate to actually make a choice, I'm offering a $15 (via paypall) bounty to the author of the post that convinces me which display(s) to buy, after I have gotten it, and if I am satisfied.
Old July 1, 2011, 08:35 PM
Arinoth's Avatar
Well if you want to run three monitors you're going to need to have a higher end AMD/ATI Graphics card or two mid to higher range Nvidia cards to pull this off. What do you have under the hood of your computer right now?
Here I am: here I remain
Old July 1, 2011, 08:42 PM
take a look at the dell u27 when in super special? 600 would close in a bit.
fold for a while for us,no need to pay us lol.
Old July 2, 2011, 08:02 AM
I updated my system specs.
Old July 2, 2011, 09:50 AM
Only monitor off the top of my head that pretty much meets all your requirements is the Asus ProArt reviewed here at HWC:ASUS PA246Q ProArt 24 IPS Monitor Review
Only potential issue would be colour saturation, but that can be re-calibrated.
You can get it at NCIX and pricematch from DirectCanada. Or if you can't get discount shipping at NCIX just buy from DC.
Old July 2, 2011, 03:04 PM
I'll take a look at that one ilya, thanks. My current idea is to get two HP ZR24W, and with the extra money saved buy a Benq XL2410. I'm not sure how well my 2+1 card setup will support this though. Anyone have any thoughts on that? I plan on borrowing/buying a Spyder3 Pro to calibrate them all with.
Old July 2, 2011, 03:37 PM
Arinoth's Avatar
Just to let you know the 2 + 1 card won't have any issues running this. I was running 2 560 Ti SLi'ed with a 550 Ti as the physx card for a good little while with no problems other then the increased heat due to all the cards having less air flow between them.
Old July 2, 2011, 03:46 PM
Anyone know any good technical reviews for the PA246Q? I usually use tftcentral to compare, but they haven't reviewed it. I'd like to know how it stacks up against the ZR24W, especially on the gamut issues.
Multi-Monitor Gaming Arinoth Display Units 12 November 30, 2010 11:09 AM
Crossfire Multi-monitor setup? nzorov Video Cards 4 April 16, 2010 08:33 AM
New to multi-GPU folding, quick setup questions... Caldezar HardwareCanucks F@H Team 33 February 7, 2010 12:06 PM
Multi Channel Setup phantom_jo Audio 1 December 25, 2009 12:36 AM
Multi GPU Setup help SugarJ HardwareCanucks F@H Team 12 November 18, 2009 05:57 PM
