<~----> 42" ips monitor for under 1200? - Hardware Canucks
Old May 12, 2011, 07:51 PM
CTA's Avatar
CTA CTA is offline
Default 42" ips monitor for under 1200?
just curious about other ips monitor...
and i found a 42" ips monitor for under 1200... (compare to u3011 for 1200ish)
NCIX.com - Buy LG 42IN Commercial Widescreen LCD Monitor 1080P 1920X1080 40000:1DC VGA DVI HDMI USB S-IPS Black - Others - M4214CCBA - in Canada
so how good is this? did i miss something?
of course its not in stock... just curious... ;p
NEW: customize case, hx100, i7 920, supreme hf, x58 sabertooth, 3gbx2 ram of ripjaws, xfx hd6950 CF. vertex 2 60gb, seagate and hitachi 1tb, dual mcp355 with ek rex v2, 2x koolance ar697, 2x mcr320, 6x zm-f3 fans.
OLD: cm 690, hx620, intel q9450, True Black, ga-ep45-ud3p, 2gbx2 ram of mushkin xp2 8500, xfx 285. wd caviar se16 640gb, 4x zm-f3 fans.
Old May 12, 2011, 07:57 PM
I'm no pro, but here are a few things I am noticing.
The aspect ratio is 16:9 which is less than optimal IMHO. The point that hurts the most is the resolution which is just 1080p, whereas the U3011 is a fare bit bigger, I forgot the exact numbers, but something like 2500 x 1600. So the image will look better from a closer viewing distance than this one.
Old May 12, 2011, 08:29 PM
ipaine's Avatar
As said by Kilauea, the big difference is in the resolution. That 42" is at a standard TV 1080p resolution, while the U3011 is at 2560x1600. So you get way more screen real estate with the 30".
Also depending on how far you are sitting from the monitor the 42" will not look as good as the u3011. Plus I was looking and that 42" is designed more for a video wall application so I'm not totally sure how it would be for something like gaming. Really if you want 42" @1080p then you are better off just getting a nice TV for less than that monitor, but if you want a good monitor for your computer then the U3011 is a very good monitor.
"Nothing sucks more than that moment during an argument when you realize you're wrong."
Old May 12, 2011, 08:32 PM
CTA's Avatar
CTA CTA is offline
i thought its lcd monitor... not tv lcd... :?
[WTB] 27"+ IPS Monitor acameron56 Buy/Sell & Trade 2 September 1, 2010 10:52 PM
Dell U2410 24" 1920x1200 H-IPS Monitor YoungMan Display Units 10 January 15, 2010 12:48 PM
[FS] LG 30" Monitor S-IPS panel, 2560X1600, almost new, mint, works perfectly - Cheap. btdvox Buy/Sell & Trade 13 March 21, 2009 12:10 AM
[FS] LG 30" Monitor S-IPS panel, 2560X1600, almost new, mint, works perfectly - $975 btdvox Buy/Sell & Trade 8 March 3, 2009 01:22 PM
[FS] LG 30" w3000h S-IPS Monitor- bought from NCIX, 2560X1600 less than 3months old btdvox Buy/Sell & Trade 0 January 29, 2009 03:36 PM
