Old January 22, 2008, 11:36 AM
Default Samsung 216BW settings?
I picked up the samsung 216BW at FS on boxing day for 229.00. I had to exchange the monitor 3 times due to really bad backlight bleeding until I got one with just a little bleed at the top. I was debating between this and the 222BW but for the extra .4 I wasn't going to worry about it.
What do you have your contract and brightness set too for playing games. I find that this Panel is not as bright compared to my LG L222WT
Old January 22, 2008, 01:29 PM
Thund3rball's Avatar
That monitor has a rating of 300cd/m2 which should be more than enough "brightness" without burning your eyes out. Maybe you need to do some calibration. My Dell2007WFP has the same rating and I can't push it past 200cd/m2 without smoke emanating from my corneas.
Here's a good read on calibrating the 226BW A & S panels. My guess is your 216bw is closer to the A panel tested in that review. I believe there is downloadable profiles too in that review. You might try those?
You may also want to Google monitor calibration and try some online techniques which usually means you eyeing the tests so it won't be perfect but you might get an improvement.
A pretty decent way to get accurate colour out of your panel would be to use a Spyder or similar type of monitor calibration device.
Hope this helps? -cheers
"this is not troll. this is real deal!" - hohohee
Desktop:
See the drop down!
Laptop: Dell XPS M1530 \\ T7500 2.2GHz \\ 3GB 667 \\ 6 Cell \\ 8600M GT \\ 200GB 7.2K \\ WSXGA+ \\ Bluetooth/Wireless \\ MS Blue Track Mini \\ Vista Ult. (RED)
HEATWARE
Old January 22, 2008, 02:55 PM
will do thanks man
FS: Mac Mini G4 / Samsung 204B LCD / Samsung HD960 Upconverting DVD (Faroudja) Thund3rball Buy/Sell & Trade 13 March 7, 2008 09:21 AM
Setting XFI Card and Ultra High Settings in BF2... Canadianguy Audio 10 December 4, 2007 09:12 PM
Bad overclock settings? magictorch Overclocking, Tweaking and Benchmarking 0 December 2, 2007 12:59 PM
initial settings Jim CPU's and Motherboards 3 July 23, 2007 02:17 PM
Check your default HD settings sswilson Troubleshooting 5 July 7, 2007 05:37 PM
