-   Display Units (https://www.hardwarecanucks.com/forum/display-units/)
-   -   Samsung Out of Warranty P2070 DVI not detected (https://www.hardwarecanucks.com/forum/display-units/41827-samsung-out-warranty-p2070-dvi-not-detected.html)
yanhchan March 21, 2011 10:46 AM
So a workmate of mine brought me a Samsung P2070 that isn't being detected or receiving signal, just ran out of warranty last week. I plugged it into my work PC's DVI port to test just now its giving me the blinking "Analog" "Digital" box on the top left.
As far as I can tell from the menu everything display wise is working. I'm not sure if its the Monitor's DVI connection that is shot. Waiting to try a different DVI cable but from what I'm told it just started not being detected over the weekend. No changes to her PC/OS/Drivers, no changes in hardware as well.
Back when i dealt with a lot of refurbished monitors I recall someone telling me about some INI file for the newer monitors anyone want to further elaborate this for me? Thanks!
ZZLEE March 21, 2011 11:32 AM
Plug it in with an Analog conector seifit comes on.
Set to defalts turn it off the thi DI agian ?
yanhchan March 21, 2011 01:19 PM
Solved, turns out DVI port was dead on my friend's PC. Got it running via VGA to DVI Thanks for your help man!
