Old January 16, 2008, 01:01 AM
Default HDMI
This is sort of off topic, I have a 46'' Sony LCD.. It only has 1 set of jacks for an HDMI plug in. I currently just upgraded to an HD Satellite. So I'm wondering, is there any type of plugs I can get or an adapter, that will allow me to have 2 HDMI jacks in my TV, I'm kind of wondering because I have the satellite I wish to hook up, and also I have a X360, and in the works a PS3.
Maybe there is something I can get that will just add on to the back of the TV and change my 7 video channels into some other HDMI capable ones.
Old January 16, 2008, 01:03 AM
hdmi switch box
Old January 16, 2008, 01:19 AM
Awesome man, I didn't think Switch Boxes came with remotes.. I was gonna be pissed if I had to walk up and switch em, or change the plugs for either! Thanks man.
Old March 4, 2008, 02:37 PM
Trial Member
Default HDMI switch will solve your problem
Pretty common problem and I had same issue. I have a Pansonic LCD with only 1 HDMI input and wanted to connect 3 HDMI sources: cable DVR, PS3 and a PC vid card.
I ended up using a peripheral HDMI switch . It has 5 HDMI inputs and allows 5 HDMI sources to connect to it and sends the one you select to the HDTV.
I tried a HDMI splitter cable, and some other HDMi switches, but they did not work.
Good luck.
Old March 4, 2008, 05:47 PM
cdn_Madrach's Avatar
Here is one at NCIX http://www.ncix.com/products/index.p...s&promoid=1055
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
Silverstone Strider 1kw modular
4870x2
Ocz Vendetta 2
Top deck Tech Station
Samsung dvd
Asus P5E VM HDMI (g35) + PowerDVD = No go topaimz CPU's and Motherboards 1 February 9, 2008 08:20 PM
Dvi to Hdmi adapter? cdn_Madrach HTPC Systems & Software 12 October 24, 2007 10:46 AM
Wireless HDMI UNESCO HTPC Systems & Software 0 January 19, 2007 07:57 PM
ATI with HDMI out ? y eye Video Cards 1 January 3, 2007 06:11 PM
