Old December 31, 2007, 04:57 PM
Default Looking for new monitor
Currently I have a (very cheap) 22" widescreen monitor and I am looking for one more in the 30"+ range. I have a 8800gtx video card, 2gb ram and E6850 processor so would I experience a major slowdown on games with this setup and a large resolution monitor? Oh and as for price range, anything below 1500$ or so.
Old December 31, 2007, 06:19 PM
JD JD is offline
A 30" monitor will run 2560x1600. If your going to be gaming at that resolution (you should else it won't look very good), I'd think you need SLI 8800GTXs to play newer games on high settings, possibly 4GB of RAM (then you'd need a 64bit OS), and perhaps overclock the CPU. You won't be running Crysis on high settings regardless. Tri-8800Ultras couldn't even do it all that well.
The best is probably the Dell UltraSharp 3007WFP-HC. It's only $1275 right now.
Old December 31, 2007, 06:53 PM
Fine with me as I didn't much care for crysis. I'll probably give it a second go later though. That one looks interesting, kinda funny that it seems to have a '9-in-2 card reader' built in, at least the tech specs say. Any good 32" ones around?
Old December 31, 2007, 07:49 PM
JD JD is offline
Yeah it does have a card reader built in. 30" is the max I've seen for monitors though. Anything larger and you move into TV territory. You could get a 1080p TV (1920x1080), but you'd probably have to sit further back to see it so that it's clear and crisp.
Old December 31, 2007, 08:03 PM
I've been looking at the sharp aquos 32 inch 1080p. Seems pretty nice.
LCD Monitor or LCD TV Brando737 Display Units 5 February 13, 2008 01:51 PM
Need Help Picking a LCD Monitor BALISTX Display Units 31 October 26, 2007 07:17 PM
Need help choosing monitor Kessler Display Units 10 July 16, 2007 09:47 PM
USB monitor anyone? Babrbarossa Reviews & Articles from the Web 0 June 18, 2007 01:19 PM
tv or monitor ? Jim Display Units 2 April 14, 2007 01:42 AM
