Originally Posted by Ash Yup, and I get this like jittering, it's defiantly smoother with vsync but not perfect by any means. I am going to fittle with the settings a bit see if I can make it smoother. I may end up going 120hz anyways because people who have them that play the game that it eliminates it all together. Likely going to just have to splurge and try it |
Probably because you're running a GTX 460. A three year old midrange card paired with a 120Hz monitor probably isn't the best idea if you're buying it for a smoother experience over 60Hz IMO.
Also considering you're running a Phenom II (overclocked?), you're going to have to near max out the graphics settings to remove the CPU bottleneck at high resolutions, but then you're graphics card is working more and you may experience some choppyness and/or stutters. It's all about balance if you want the best experience. You can't just ignore something important like what CPU you use because you don't think it matters or it's good enough because you can't afford the upgrade.
My advice to you would be to upgrade your video card first if you still plan on buying a 120Hz monitor, followed by a 6 core FX chip or a SB/IVB i5 and motherboard.
