-   Display Units (http://www.hardwarecanucks.com/forum/display-units/)
-   -   Just hooked up my Acer 22" 223w (http://www.hardwarecanucks.com/forum/display-units/3805-just-hooked-up-my-acer-22-223w.html)
Canadianguy December 25, 2007 09:48 PM
I have a question about one setting in nivida control panel under "change the signal od HD format".I have it on non change the HD format,the highest is 1081i or p.Should i have it on one of the 1080 setting?
Thanks
Jmac December 25, 2007 11:38 PM
No ... Leave it at 1680x1050 ...
Squeetard December 26, 2007 10:48 AM
If you want a second opinion, I second what jmac said. Those options are for if you have an HD tv hooked up.
