<~----> Dell 2311H - Hardware Canucks
Old August 9, 2010, 07:46 PM
lcdguy's Avatar
Default Dell 2311H
Well i just got my dell monitor and i love it. I liked it so much that i ordered 2 more. i can't wait for them to show up so i can try out some eyefinity goodness.
Old August 9, 2010, 08:22 PM
ZZLEE's Avatar
Default Nice
sounds like fun
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old August 9, 2010, 08:53 PM
lcdguy's Avatar
yup. can't wait.
Old August 16, 2010, 10:09 PM
Nice, I got one myself. Hoping for a dual setup shortly since I feel triple will be too wide for my uses right now.
Old August 17, 2010, 10:41 AM
lcdguy's Avatar
Well i got my monitors and love them to bit's really nice. Then only downside i have run into eyefinity is with distortion on the side monitors but there is not much i can do about that as it's a nature of the method how game engines render scenes. Also mass effect 2 doesn't support eyefinity.
In regards to getting 2 monitors. the one issue i ran into that in FPS games is that your crosshair is usually buried by the bezel with 2 monitors.
Old August 17, 2010, 04:00 PM
CroSsFiRe2009's Avatar
Hows the anti-glare coating on it? I was almost set to buy one from Dell during their sale but held back after finding numerous reports of the panels having a bit too much AG coating and end up causing uneven light distribution
Old August 18, 2010, 11:33 AM
lcdguy's Avatar
i don't notice it but then again my eyes aren't exactly in prime condition (blind as a bat without glasses)
Old August 19, 2010, 01:06 PM
Didn't notice any problems with that either (I bought mine a month ago)... but then again, I haven't been looking specifically for uneven colours
Old August 28, 2010, 01:23 PM
Is the U2311H better then the 2209WA?? and hows the backlight bleeding?
Old August 28, 2010, 08:02 PM
lcdguy's Avatar
better can be subjective. Ir depends on what your comparing it to. For connectivity i think the 2311 wins out since it has vga/dvi/dp so it's popular with eyefinity users. but the aspect ratio is only 16x9 which some people don't like. I don't notice to much bad bleeding but then again i have 3 so there is alot of extra light in my room. When it comes down to it. it's probably the cheapest ips panel monitor with native display port and a 3 year ultrasharp warranty.
Why Dell is going down the tubes Sagath Off Topic 26 July 21, 2010 10:36 AM
Dell 2209WA $209 @ Dell MrDiaz Display Units 15 March 21, 2010 01:16 AM
Dell 2209WA howpet Member Reviews 15 June 29, 2009 12:52 PM
Dell M1330 darkorb Mobile Computing 14 August 13, 2008 05:25 AM
