Old August 8, 2010, 10:45 PM
Default LCD Monitor Arms
Hello, I've been looking for a decent articulating arm for my 23" monitor. The stand that comes with the Samsung 2343BWX is just about useless, as it can hardly be adjusted whatsoever. I live in an apartment and so have somewhat of a space constraint, and think it would be great if I could swing out the arm and use my monitor to watch TV programs or movies from my bed. A thread here mentioned monoprice back in April.
For only $20.16 each when QTY 50+ purchased - 3 Way Adjustable Tilting Desk Mount Bracket for LCD (Max 33Lbs, 10~25inch) - Black | LCD Desk Mount Brackets
Which would come to fifty some with shipping. I've seen Ergotron arms at Dell.ca, but I read that those are not easily adjusted whatsoever, one needs a little tool to adjust the screws. And I don't want to go over $100.
Any suggestions?
Old August 8, 2010, 11:02 PM
lowfat's Avatar
Your link doesn't work first off.
And secondly I actually use a monoprice arm for my extremely heavy 27" iMac. The one I have screws to my desk. It works well enough. It has no forward/back tilt. Not sure if that is something you need. And moving the height of it is hard. Most of the time when I adjust the height the display starts so slide down a bit everytime.
Mael
Big Lian Li
Forever Alone
Old August 8, 2010, 11:14 PM
Thankyou for your quick reply, that link should be fixed by now. The one at monoprice is by far the cheapest, and the only problem seems to be that one cannot rotate the stand from portrait to landscape. I think that having the ability to move the monitor out of the way( and elevate it off the table) would potentially save a lot of space on the desk.
Old August 8, 2010, 11:29 PM
lowfat's Avatar
This is the one I have and it definitely does rotate. Almost too easily.
For only $18.85 each when QTY 50+ purchased - Adjustable Tilting Desk Mount Bracket for LCD (Max 33Lbs, 10~23inch) - Black | LCD Desk Mount Brackets
Mael
Big Lian Li
Forever Alone
Old August 9, 2010, 09:18 AM
So the monitor arm that you have lowfat, it attaches to the desk via several screws instead of a vise clamp? And does it still secure to the desk well?
Old August 9, 2010, 10:39 AM
LaughingCrow's Avatar
Desk mounted articulated arm
15" to 25" Articulated-Arm Desk Mount - Lee Valley Tools
Old August 9, 2010, 12:59 PM
That model looks good Laughingcrow, but the only difficulty is whether or not it can rotate the display from landscape to portrait. I haven't been able to find any documentation for it.
Old August 9, 2010, 02:25 PM
Trial Member
Default good info
I use these things everyday and even sell a few as part of gaming packages. I like sturdy stuff i will only have to buy once...even if these are too rich for your rig ergotech gaming suite has good info
Old August 9, 2010, 03:33 PM
You might want to actually try looking at your monitor in portrait though first. TN panels aren't exactly the best choices for doing things in portrait mode.
Old August 9, 2010, 03:46 PM
True, but I'm hoping that the tilting abilities of an articulating monitor will correct any viewing angle issues. Besides, when in portrait mode my monitor won't really be in portrait mode. I'd be on my side viewing the monitor from my bed. Why get a TV when that setup should work just fine for work and comfort
If that monoprice monitor that lowfat mentioned has a simple vice clamp that I don't have to mess around with screwing things into it, I'm game.
Trying to use my LCD TV as a second monitor Lpfan4ever Troubleshooting 7 April 30, 2009 06:19 AM
[WTB] 22'' to 24'' LCD monitor Jacka Buy/Sell & Trade 1 January 27, 2009 05:46 PM
What's the diff between buy a lcd tv and an lcd monitor? Mark Display Units 9 October 27, 2008 07:38 AM
LCD TV as a Monitor? mattlef Display Units 17 September 10, 2008 05:25 PM
LCD Monitor or LCD TV Brando737 Display Units 5 February 13, 2008 02:51 PM
