-   Display Units (http://www.hardwarecanucks.com/forum/display-units/)
-   -   Please clarify DELL U2410 dimensions (http://www.hardwarecanucks.com/forum/display-units/34860-please-clarify-dell-u2410-dimensions.html)
Denis54 August 4, 2010 08:17 AM
The DELL web site shows that the dimensions of the U2410 are: 19.4 X 22.0 X 7.9. Since it has an height adjustable stand it is not clear wether the 19.4 height is the maximum or the minimum.
What is the maximum height? Is it 19.4?
What is the minimum height?
What is the height of the screnn itself including the bezel?
Kilauea August 4, 2010 08:34 AM
As measured on my desk, when its at its lowest state, the top is at 16 in, when maxed, it is at 19 7/16 in.
Denis54 August 4, 2010 08:47 AM
Thanks Kilauea. That was what I was looking for.
If it is not asking too much, would you mind measuring the size of the screen itself? I guess it should be approximately 14.5 inches.
Kilauea August 4, 2010 09:07 AM
In height from outside to outside, its 14 3/8in.
