<~----> eyefinity question - Hardware Canucks
Old July 23, 2010, 01:37 PM
Question eyefinity question
ok got 2 questions about eyefinity.
i was looking at 3 asus VW246H Newegg.com - ASUS VW246H Glossy Black 24&#34; 2ms&#40;GTG&#41; HDMI Widescreen LCD Monitor 300 cd&#47;m2 ASCR 20000&#58;1 &#40;1000&#58;1&#41; Built-in Speakers
hooked up to a single 5970
1) does the added monitors effect frames per second of games in any way?
2) those particular screens have speakers on them will all 3 monitors have sound coming out of them or just one?
Old July 23, 2010, 01:58 PM
scruff's Avatar
I know now with my new setup my SLI 275 GTX's are struggling a little with three monitors (24" ) compaired to one 24" monitor .Not sure if they all will have sound but if they are connected up the same it would make sense. Why don't you buy 3 monitors without speakers and buy a good set of speakers. I personally havn't heard good sound out of a monitor in a long time
Old July 23, 2010, 02:00 PM
1) Of course. The video card has to render three monitors worth of stuff instead of just one. There's a pretty significant performance difference.
2) That depends on how you have your sound configured. If you don't connect the speakers then sound won't come out of them.
Old July 23, 2010, 02:04 PM
theres a very simple answer to your question. you will have ZERO performance issues with the 5970 and 3 x 1920 x 1080 monitors.
The 5970 is = to 2 x 5850, or 5870 if you give it a voltage bump and oc a bit.
On my current setup i have a SINGLE 5870 and run 3 x 1680 x 1050 with maximum IQ on every modern game ive played (which is all the most recent) with very good framerates. your graphics card is capable of being TWICE as good as mine, so you will have no issues at all.
On the sound, each monitor will have a cable that is supposed to run from the monitor to your audio out port in the back of your pc. unless you get a splitter, you'll only be able to plug in ONE monitor at a time, which is ok because if you like to have your audio in stereo you'll not want all 3 monitors hooked up at once.
vista 64 on these rigs
Q9450 @ 3.5Ghz | E8400 @ 4.2Ghz
8gb Muskin Redline. | 2gb Kingston Hyperx
________________________________|_________________ ______________
EVGA 780i FTW ----\--||___||--/---- EVGA 780i SLI
Antec TP Quatro 1000W \ :==^==: / Antec TP Quatro 850W.
Nvidia 9800 GX2 X 2 SLI \|--o--|/ Nvidia 8800 GTS X 2 SLI
1X 500GB Western Digital. \_____/ 3X 150GB WD RAPTOR RAID-0
Old July 23, 2010, 03:04 PM
Originally Posted by tzetsin View Post
1) theres a very simple answer to your question. you will have ZERO performance issues with the 5970 and 3 x 1920 x 1080 monitors.
anyone have the tie breaker??
Old July 23, 2010, 03:15 PM
He didn't say you won't see a performance difference. He said you won't have any issues. Your performance will be lower than it would be with a single monitor, but your card should still be enough to drive all three monitors without having to sacrifice on image quality.
Old July 23, 2010, 03:22 PM
what kind of performance difference are we talking 1-2 fps loss or 20-30 fps loss
Old July 23, 2010, 03:45 PM
More like 20-30 FPS.
Old July 23, 2010, 04:51 PM
20-30 that dont matter, eyefinity is more than worth the loss, and the loss will be negligable in your case.
Old July 23, 2010, 05:16 PM
wow, ffxiv, cod mw2, dirt 2, maby crysis 2 never played the first one but then again never has a rig that would run it.
Got my Eyefinity going on!!! ontariotl Video Cards 68 October 17, 2010 03:17 PM
Eyefinity 6 edition question. Still Need Active adaptor? Chromey Video Cards 5 May 14, 2010 09:25 AM
eyefinity ... tzetsin Troubleshooting 3 May 3, 2010 08:57 AM
Eyefinity Question... xXxRithxXx Video Cards 2 March 5, 2010 03:38 PM
Jump to Eyefinity or not? CMetaphor Video Cards 38 October 9, 2009 04:17 PM
