-   Display Units (http://www.hardwarecanucks.com/forum/display-units/)
-   -   22 Inch LCD monitor selection?! (http://www.hardwarecanucks.com/forum/display-units/3394-22-inch-lcd-monitor-selection.html)
abs0Lut November 25, 2007 12:19 AM
Hey guys, out of the 2 which one would you buy when you could get both for 299$ each?
Samsung 226BW:
NCIX.com - Buy Samsung SyncMaster 226BW 22IN Widescreen LCD Monitor Black 1680X1050 3000:1 2MS VGA DVI-D HDCP - LS22MEHSFV/XAA In Canada.
LG L226WTY-BF:
NCIX.com - Buy LG L226WTY-BF 22IN Widescreen LCD Black 2MS 1680X1050 3000:1 300CD/M2 VGA DVI Tilt Swivel Monitor - L226WTY-BF In Canada.
Thanks a lot.
Jmac November 25, 2007 12:33 AM
Of those 2, I'd take the Samsung ... although I'd probably spend more money and get a monitor w/ a better panel, personally.
Digitaldemon November 25, 2007 12:50 AM
I would lean towards the lg.. mainly cause i have had more success with them... I only had 1 sam.. and a few issues with it...
the one thing that is annoying is there is no dvi cable with lg's....
currently I am on a L226WA
enaberif November 25, 2007 12:57 AM
Really isn't a "better" panel due to all low end LCDs being a TN panel and some of the 24s will be the SIP (i think thats what it is) and even then they are going to TN I've heard.
And those two I'd go with Samsung.
darkorb November 25, 2007 01:15 AM
iv had both, LG wins by FAR
Babrbarossa November 25, 2007 06:54 AM
I'm happy with my revent LG purchase (same panel, diffrerent model), and since then I've heard some other raves about it, but also have heard concerns about ghosting although there's no ghosting here- I chose mine based on a side-by-sode comparison
b1lk1 November 25, 2007 07:33 AM
I just bought that exact same LG model and it is brilliant. I sold my Dell 2407WFP-HC and was forced to go with a smaller budget unit and it has not disappointed me for a second. Best looking TN I've ever had the pleasure to use.
Jmac November 25, 2007 12:14 PM
I think you misinterpreted what I was trying to say which is that I would not buy a monitor that uses a TN panel (as those 2 do). Monitors that use MVA, PVA, and IPS panels cost a lot more money (thus why I said I'd spend more money) with even a 20" PVA monitors starting around $400.
Squeetard November 25, 2007 12:33 PM
I got my 24" LG MVA panel on sale at FS for $549. Ran it side by side with the 22" Samsung and there was no comparison. the lg was superior in every way, even gaming.
abs0Lut November 27, 2007 09:45 PM
Your LG is almost double the cost of the 22" Samsung. I really want to know how the two 22" monitors stack up against each other.
