Old June 28, 2010, 12:45 PM
Default Arent all screens HD?
I have gotten alittle confused, that on the HD 5970, is says it requieres a monitor which is HD-ready.
But havent all monitors been HD for many years?
it is only the TV, which has been behind?
Or do i need to get a "Special" screen for my HD 5970?
My screen is a 1680 x 1050 Widescreen Dell, 2 years old model. Is that HD-ready?
Old June 28, 2010, 12:59 PM
headsh0t's Avatar
You'll be fine...
Old June 28, 2010, 09:56 PM
Caldezar's Avatar
I'm pretty sure this is one of two things:
a) The package states that viewing an HD image requires a screen resolution capable of that image. (You won't be displaying true 1080p on a 15" standard res monitor)
or
b) You're actually looking at the feature that reads: "requires a HDCP complient screen" or whatever the wording is. And HDCP is a security protocol, not a display resolution.
Either way, there's no concern using that video card with your monitor. Except that it's massive overkill for that res...
Old June 28, 2010, 10:13 PM
ForTheGG's Avatar
+1, you'll have no problems. To clarify, true HD is 1080P resolution, so not all displays are truly HD. It depends on how you define High Definition anyways.
Lian Li PC O11 Dynamic
Intel Core i5 4690K
Asus ROG Maximus VII Formula
EVGA GTX 780 SLI
8GB Corsair Dominator 1866
Samsung EVO 840 (1TB + 250GB)
Corsair AX850
Old June 28, 2010, 11:27 PM
that and theyre working on ayet another level of hd, something that'll make 1080p look like 720p but worse :) and $$ viable for the poor masses(us).
Old June 29, 2010, 05:44 AM
lcdguy's Avatar
Don't forget there are other true HD resolutions.
720P - 1280x720
1080p - 1920x1080
2k - 20481536
4k - 40963072
HDCP is a security protocol as discussed above that has to do with Hidef and blu-ray content secured with that protocol. Also you need a HDCP compliant display device for Hi-def console gaming.
Old July 5, 2010, 01:00 PM
10e's Avatar
10e 10e is offline
Don't worry about it. You will have no problems with this combo.
Post your Design Garage screens! sertz Video Cards 5 May 10, 2010 04:02 PM
Frequent Blue Screens-HELP! flyingdutchman Troubleshooting 35 January 30, 2010 04:53 PM
Random Freezing and Black Screens jcmaz Troubleshooting 20 January 3, 2010 08:18 AM
See the Laptop With Two Full-sized Screens Unknownm Press Releases & Tech News 4 September 4, 2009 06:07 AM
Glossy Framed Screens enaberif Display Units 16 February 27, 2008 10:47 AM
