Old June 16, 2010, 07:58 PM
Default Anyone tried the Dell U2211H?
Just wondering if anyone has given the dell U2211H a try, or has heard anything positive or negative about it? im running a Samsung 22" T220HD right now, this seems to fit my requirements for something thats a higher resolution and wont take up a large amount of desk space. Any other suggestions for new monitors that are easy to get in the lower mainland (I.E. NCIX) would be appreciated as well.
Old June 21, 2010, 07:15 AM
10e's Avatar
10e 10e is offline
These are pretty good screens.
They are IPS panels which have superior viewing angles to TN panels, such as the one in your T220HD. For example, if you look at the T220HD from below, the image may invert, and you can also probably notice that when you look at it straight on, the top is darker and has higher contrast than the bottom.
The U2211H doesn't have any of these issues. Also it will have lower input lag than the T220HD. Input lag is the phenomenon where you move your mouse and the cursor seems to lag slightly behind it.
Here's a pretty decent review:
Dell U2211H Review
Too bad I didn't see this earlier, the U2211H was on a one-day deal last week for $219.99
Dell 2209WA $209 @ Dell MrDiaz Display Units 15 March 21, 2010 01:16 AM
dell in vancouver? RedLight Display Units 6 August 7, 2009 12:02 AM
A dell buy mailaw New Builds 2 November 27, 2008 07:04 PM
