Old May 31, 2010, 03:07 PM
Helix's Avatar
Default Dell 2209WA or U2311H
Title says it all. Since they're the same price, I'm slightly worried about the 8ms response on the U2311H for games, but you do gain another inch. Also, there have been reports of tinting. The 2209WA is slightly smaller, 16:10, does 75Hz, but only has a DVI and VGA connection and is EOL.
Opinions? I'd like to order soon.
Old May 31, 2010, 08:01 PM
there's also the resolution difference.
if you don't care about the 23" extra res, or the extra inputs, i would go with the 2209wa just because it's a proven performer.
Old June 2, 2010, 09:00 PM
2209wa all the way
Old June 6, 2010, 09:25 PM
Helix's Avatar
I ordered the 2209WA, got it on one day sale for $100 off!
Old August 29, 2010, 12:57 PM
im unsure on which one to get anyone tried both or have any opinions on the matter?
Old September 23, 2010, 01:44 PM
If you don't mind the aspect ratio then go with the 2311H, for the lower price and the right aspect ratio (as many would say), the 2209WA. Either way you can't go horribly wrong.
Old September 23, 2010, 02:01 PM
Jake_HT's Avatar
16:10 FTW... 2209WA. Love mine. Will never get a 16:9 for PC use, silly.
And I doubt you'd notice the difference between 6ms and 8ms.. I didn't notice going from 2ms to 6ms.. this monitor runs at 75Hz as opposed to 60, whatever difference that makes?
http://jakeht.deviantart.com/
Old September 24, 2010, 12:02 AM
75hz makes a huge difference in many ways. Among others reasons, it's very important for a gamer. Higher is preferable, but the only way to go higher right now would result in getting a TN panel or getting a CRT.
The 2209WA is really the only monitor I'd even consider using right now. It's just that good.
Old September 25, 2010, 10:58 PM
Helix's Avatar
It's an excellent monitor. Perhaps not the best for FPS games, however it's great for RTS games.
Old October 2, 2010, 01:55 PM
^ You want to elaborate more on that statement? Or provide a much better alternative, 'cause that seems wrong in many ways.
Dell 2209WA $209 @ Dell MrDiaz Display Units 15 March 21, 2010 01:16 AM
[FS] Dell 2209WA Zankras Buy/Sell & Trade 0 January 9, 2010 01:55 AM
Dell 2209WA howpet Member Reviews 15 June 29, 2009 12:52 PM
