Old May 22, 2010, 11:11 AM
Default Eyefinity...Worth It?
I'm toying with the idea of adding a 3rd monitor to my desktop. I was thinking of getting the same model as my current two, Samsung P2250, before they no longer are available. It does not have a displayport input so I would need to get an active adapter as well. But is the expense and deskspace real estate worthwhile for gaming immersiveness or is it an unnecessary fad?
System Spec Peripherals: NZXT Kraken X42 CPU cooler | Zalman MFC3 fan controller | Steelseries Apex M800 kb | Steelseries Sensei mouse | Logitech Z-2300 2.1 speakersDrobo FS 6.5TB Synology DS1515+ 15TB
Laptops: Asus G74SX-DH71 | Asus G752VY
Surface Pro 4 Core i7/256GB
Old May 22, 2010, 02:18 PM
Its been Proven By a Few OC.net Members that a Non-Active displayport Adaptor running @ 1920x1080 per monitor, Runs Eyefinity Without a Issue.
As for the real question here, Im trying to find a Reason Not to Buy 2 more 24" for eyefinity myself.
The only thing as of right now that is Stopping me is... WIll i be able to run MAX everything with a 5870.
Ive been told NOT a Chance.
With games Like BC2/Fallout3/Newvegas (coming) Im thinking ill need Crossfire Just to make everything pretty again
I love the Idea of Eyefinity, But a little old 5870 Might not be able to cut it for me.
Old May 23, 2010, 06:27 AM
Digikid's Avatar
No...you DO need an active adaptor. I have tried a few non active ones from friends and they did not work.
That said....I do not believe that eyefinity is worth it.
Do you get motion sick?
Old May 23, 2010, 10:43 AM
Read this and Get all the info you need.
Proof...passive adapter WORKS.......
Mal's Eyefinity Project (Info, Pics, Vids) (Using PASSIVE DP to VGA adapter!) - Overclock.net - Overclocking.net
Old May 31, 2010, 10:59 AM
Thanks for the feedback. I think I will wait. I get the feeling video cards need to get beefier. Also more monitors either need to support displayport connectivity or the cards themselves need to do away with that requirement (i.e. 3 DVI connections).
Old June 1, 2010, 03:23 PM
ultraman7k's Avatar
So has any one here tried using the non active DP/DVI/VGA adapter?
Old June 2, 2010, 05:01 PM
Im sure i posted something that Might involve ^^^^ that question...
Old June 4, 2010, 06:04 PM
DRZDuke's Avatar
Is Eyefinity worth it ? I'd have to say that it really depends on what games/programs you are using.
For flight simmers or racing sims Eyefinity is invaluable. The extra FOV (field of view) afforded by eyefinity setups is fantastic for flying or driving, being able to see out the side windows for formation flying or when a guy is pulling alongside you in a Nascar at close to 200 MPH is far superior to a single display setup.
Also for people that have multiple screens running for work eg: web design, CAD etc ... the expanded desktop again is a huge improvement.
As for FPS's ... if you are susceptible to motion sickness ... stay away, the added FOV really exagerates that feeling of movement and can make you quesy in a real hurry. The benefit of course is that again FOV is largely expanded giving you a much expanded view of the battlefield (excellent for snipers) so much so in fact that some peeps online call eyefinity a cheat because you do have a serious advantage.
As for the 5870 not having enough power ... I call bull$%*@ !
A buddy of mine just bought a 5870 and runs Battlefield Bad Company 2 at 5760X1200 resolution across 3 27" monitors and gets well over 60 FPS if V-sync off and it stays pinned at 60 with it on and that's with all the details maxxed ... I would never have believed it if I hadn't seen it but it's true ... the 5870 has plenty of juice.
It all comes down to personal preference I think, I myself have been a multiple monitor user for years and could never go back to a single monitor solution and for my money ATI has hit the nail on the head with Eyefinity.
Old July 4, 2010, 12:22 PM
Piderman's Avatar
If your looking into Eyefinity then you should also consider nividia's option because they both work good it will end in your preference in graphic cards, monitors and what your using this all for.
Old July 4, 2010, 01:00 PM
Technokat's Avatar
Nvidia's option requires SLI though.
eyefinity thread. kyle_L Case Mods, Worklog & Gallery 49 November 3, 2010 08:53 PM
Got my Eyefinity going on!!! ontariotl Video Cards 68 October 17, 2010 03:17 PM
eyefinity ... tzetsin Troubleshooting 3 May 3, 2010 08:57 AM
Xfire with eyefinity MarkOne Video Cards 12 February 17, 2010 08:18 AM
Jump to Eyefinity or not? CMetaphor Video Cards 38 October 9, 2009 04:17 PM
