Old July 4, 2010, 01:00 PM
fishingfanatic's Avatar
Smile Hardware
Is 3 monitors really better than say using a big lcd/led/plasma tv? I use a 40" Bravia and love it. A 22-24" monitor just doesn't cut it for me. The amount of money spent on 3 monitors could easily get a 52" tv if you're going high end. JMHO.
Old July 4, 2010, 01:04 PM
Nvidia's option means you need to where glasses...GAY.
I dont mind watching a Movie in 3d for a few hours, But when i do a Full night of gaming, Glasses Just wont cut it.
I wish Nvidia was able to comeout with something a little more Original...
Old July 4, 2010, 03:34 PM
Yes. Resolution makes all the difference. In my opinion playing on a smaller 1080p monitor looks better than a large HDTV anyway due to the pixel density difference.
Old July 4, 2010, 05:08 PM
I agree. I'm currently using a 24" LG 1080p & plan to get 2 others to flank it. Might go smaller not sure yet. Using an ATI 5870 ofc. Looking forward to using Eyefinity for BC2.
Old July 4, 2010, 05:19 PM
Technokat's Avatar
NVIDIA's option does NOT mean you have to wear glasses. Why would you have to wear glasses to view multiple monitors? Yes if you want 3d or multiple monitor 3d you need glasses. But thats not what we are talking about.
You want to have all the same size monitors, preferably the same brand and model, so all the screens are uniform. Dont go smaller for the side screens.
Old July 4, 2010, 06:52 PM
SneakySnake's Avatar
^^ what he said, and when I sit at my desk, my 24" monitor fills a heck of a lot more of my viewing angle then my 42" TV does from 8 feet away.
i5 8400 || Strix 1080 Ti || 16 GB DDR4 3000Mhz
Old July 22, 2010, 04:35 PM
ultraman7k's Avatar
Can you go Monitor -> miniDP to DP adapter -> 5850 DP?
Old July 22, 2010, 05:02 PM
Of course. The only difference between DP and miniDP is the physical connector. Electrically, they are the same.
  #19 (permalink)
Old July 23, 2010, 01:09 AM
ultraman7k's Avatar
arrgh can't decide whether i sohuld pull the trigger on a 3rd monitor or not!
  #20 (permalink)
Old July 30, 2010, 09:33 AM
Originally Posted by Chromey View Post
The only thing as of right now that is Stopping me is... WIll i be able to run MAX everything with a 5870.
Ive been told NOT a Chance.
I just want to confirm for you right now that you CAN run the games you mentioned at full IQ with eyefinity and a SINGLE 5870. Mine had absolutely no problems.
At the OP, eyefinity will change the way you game. i've been using spanning since way back with the matrox th2g. eyefinity makes it much simpler and a 5870 can handle all your current games at max res, max IQ quite fine.
I should point out that not ALL games work well with spanning. Of course games of the future will handle it best because its becoming mainstream, but older games (ie the entire COD series) will NOT work well with eyefinity. The problem lies in the FOV (field of view) older games didnt expect that you'd be able to see across more than one monitor so they've made no effort to make sure it would look ok and in alot of cases it breaks the game.
My advice, since your seriously pondering it already, is to get it. at the very least you wont be dissapointed, at the most you'll wet your pants.
eyefinity, worth every penny hands down.
Nvidia's surround, not worth every penny. second vid card costs more than a display adapter, so does a sli ready motherboard, more powerful PSU, extra heat (fermies run increadibly hot) more power consumption and massive amount of noise induced by a second fermie.
I just want to point out that at this time i've got both ati's and nvidias surround setup. ati's is by far the better option.
vista 64 on these rigs
Q9450 @ 3.5Ghz | E8400 @ 4.2Ghz
8gb Muskin Redline. | 2gb Kingston Hyperx
________________________________|_________________ ______________
EVGA 780i FTW ----\--||___||--/---- EVGA 780i SLI
Antec TP Quatro 1000W \ :==^==: / Antec TP Quatro 850W.
Nvidia 9800 GX2 X 2 SLI \|--o--|/ Nvidia 8800 GTS X 2 SLI
1X 500GB Western Digital. \_____/ 3X 150GB WD RAPTOR RAID-0
eyefinity thread. kyle_L Case Mods, Worklog & Gallery 49 November 3, 2010 08:53 PM
Got my Eyefinity going on!!! ontariotl Video Cards 68 October 17, 2010 03:17 PM
eyefinity ... tzetsin Troubleshooting 3 May 3, 2010 08:57 AM
Xfire with eyefinity MarkOne Video Cards 12 February 17, 2010 08:18 AM
Jump to Eyefinity or not? CMetaphor Video Cards 38 October 9, 2009 04:17 PM
