Old May 9, 2010, 05:21 AM
WolfBane's Avatar
Dancing_Banana LARGE SCRREN FOR BASEMENT ,NOT A TV SCREEN PLEASE:)
looking for a large screen for my basement movie room that isnt to expensive also whats a good hd overhead projector costs and what brand?
I USE EMT ONLY
Remember... Four boxes keep us free: the soap box, the ballot box, the jury box, and the cartridge box.
Old May 9, 2010, 10:49 AM
Polygon's Avatar
What's your budget and what screen size would be good? Do you have a preference between DLP and LCD?
Full HD 1080p projectors start at about $1,000
you can snag 720p projectors for as low as $700 now
Here's a decent 1080p DLP projector
NCIX.com - Buy BenQ W1000 HDTV 1080P DLP Projector 1920X1080 2000 ANSI 3000:1 2XHDMI Component - W1000 In Canada.
For screens what size would fit nicely in your basement? Any restrictions? 80-120 inches I believe is the norm for Projector screens. Make sure you get a 16:9 ratio screen though (if you get a 1080p projector)
NCIX.com - Buy Grandview FA-P92 16:9 92IN White Matte Manual Projector Screen - FA-P92 In Canada.
'Do not wish for easier lives, wish to be stronger men'
Old May 9, 2010, 02:34 PM
tri5cui7's Avatar
What's you're price range? I might get flamed for this but Insignia, from futureshop/bestbuy is actually quite nice and inexpensive. you can pick up a 42inch for less than a grand
Old May 9, 2010, 07:32 PM
JD JD is offline
What are you looking for exactly? Large screens are only found in TVs. They're still LCD anyways, so it's all fine and well. 1080p resolution is fine when your back quite a few feet, even on a large TV.
Kind of sounds like your after a projector setup though. And if that's what your after, make sure you have ample room for the projector to be mounted as far back as possible and centered with where you want the screen. Otherwise you'll have to invest in some special lens to move the image over, or a short-throw projector.
Old May 10, 2010, 06:22 AM
Gellidius's Avatar
i think this "viewing distance calculator" would be usefull when searching for monitors or tv's:
Viewing Distance Calculator
Jacques
Ego cogito, ergo deus non est.
Old May 10, 2010, 08:39 AM
Eldonko's Avatar
Hardware Canucks Reviewer
I highly recommend Panasonic PT-AE4000. I watched the UFC PPV on Saturday with this projector on a 140 inch screen in HD. Unbelievable.
Old May 11, 2010, 02:24 PM
WolfBane's Avatar
Ok i am looking at (will measure soon ) a 80 x 120 screen
budget is as little as possiable but not over 2000 total
the room is about 400 foot i would say long and about 12 or so wide
and yes i am looking at a projector i guess that is 1080 p hi def
I already have a yamaha surround system so i will check what you all reccomend:)
I USE EMT ONLY
Old May 11, 2010, 04:58 PM
How about the NCIX.com - Buy Acer H5360 720P 3D DLP Projector XGA 2500 ANSI 3200:1 HDMI 120HZ NVIDIA 3D Vision Ready - EY.K0701.020 In Canada., it is 3D ready 699.99
Old May 12, 2010, 11:16 AM
I own a Panasonic AE3000, my PC is on it... i game on that (107 inch) it Rocks! 1080p gaming FTW ! :)
Project: Basement Rison Case Mods, Worklog & Gallery 8 March 6, 2010 01:52 PM
Large IDE HD Sui Storage 4 February 13, 2010 11:22 AM
Setting font sizes on a large screen 3 of 7 Display Units 0 March 17, 2009 04:26 PM
Suggestions for a large ATX with.... lowfat HTPC Systems & Software 26 September 25, 2008 10:29 AM
Large project James_8970 HTPC Systems & Software 6 January 9, 2008 10:44 PM
