Old April 20, 2010, 12:22 PM
Mark's Avatar
Question Single 5870 to run on a 2711?
I had the 3007 but ended up selling it ( to my regret ) so I'm back in the market.
Dell has a sale on both units in Canada, the 2711 for $899 and the 3007 for $999. I would like to buy the 3007 again but I'm not willing to buy another videocard in the process - so crossfire is a nono.
The question I have is if the ATI 5870 is capable of running smoothly on the 2711. If so then that will definitely be my choice. The $100 difference between the monitors is not much but adding another 5870 is ridiculous.
Does anyone know?
CHEERS
Old April 20, 2010, 01:12 PM
lowfat's Avatar
Does anyone know?
The U2711 only has 9% fewer pixels. I have my doubts that the graphical power required to drive both displays is going to differ all that much. I game @ 2560x1440 just fine, but I do use an HD5970. You might need to not play @ high detail all the time, but if you are ok w/ that I am sure the HD5870 will suffice.
Old April 20, 2010, 01:29 PM
Mark's Avatar
Now I'm not sure what to do if that's the case. I suppose the question now is which should I purchase? Is the 2711 of better image quality or should I just go back to the 3007?
CHEERS
Old April 20, 2010, 04:18 PM
lowfat's Avatar
Well the U2711 does have slightly higher pixel density. My display does use the same panel as the U2711 (although LED backlit) and I will say that it does look fantastic.
Old April 20, 2010, 04:52 PM
Mark's Avatar
The Imac 27"?
CHEERS
Old April 20, 2010, 05:51 PM
lowfat's Avatar
The Imac 27"?
Yes the iMac.
Old April 20, 2010, 08:29 PM
kyle_L's Avatar
all i can say to contribute to this is that i game at 3750x2048 and run most games at max without aa. running bc2 and justcause 2 at max with no aa i get arount 30-40fps. so it should do fine for you.
im looking for work.
Old April 21, 2010, 05:12 AM
Mark's Avatar
Hi Kyle
Which monitor do you have?
CHEERS
Old April 21, 2010, 07:00 AM
kyle_L's Avatar
3x23 inch in portrait eyefinity. looks like this:
Old April 21, 2010, 07:58 AM
Mark's Avatar
Wink
your speakers are too small
CHEERS
ASUS HD 5870 Matrix 2GB & ASUS HD 5870 "V2" Sneak Peek Comment Thread SKYMTL Video Cards 36 April 14, 2010 04:42 PM
[WTB] xfx 5870 or xfx 5870 xxx bc_tileguy Buy/Sell & Trade 7 March 31, 2010 07:35 AM
Best Single slot cooling??? jcmaz Video Cards 3 January 29, 2010 08:59 PM
Ati 5770 3-Way vs Ati 5870 Single ? JORD4N Video Cards 11 December 3, 2009 08:19 PM
