Old October 26, 2007, 11:10 AM
Hmm it seems it is a stuck pixel as it is bright blue. I tried the massage technique but it did not work. I also used some app but that didnt work as well. Damn!
Old October 26, 2007, 12:37 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Hi bobaban,
Here is a good link with detailed instructions on the various "unsticking" methods around:
How to Fix a Stuck Pixel on an LCD Monitor - wikiHow
(wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor)
Good luck!
AkG
Old October 26, 2007, 12:42 PM
Originally Posted by AkG View Post
Hi bobaban,
Good luck!
AkG
Fixing a dead/stuck pixel very seldomly ever works and its best to just live with it.
Old October 26, 2007, 12:59 PM
qwerty's Avatar
Hehe, when I read that one should massage the d/s pixel I thought you were j/k. It never dawned on me that this can work sometimes. Neat.
Old October 26, 2007, 01:36 PM
AkG's Avatar
AkG AkG is offline
Hey man like they say Your Mileage May Vary. Does it always work...nope. Does it work often enough that it is worth a try...Yes. DOA pixels usually are just that: DEAD. I have brought a couple back from the dead but most likely that was cases of stuck pixels, and not really ALL dead. "Mostly dead" or "Stuck" pixels are usually unstickable...not always but enough that its worth your time.
Honestly, will he be any worse off if it doesn't work?
Reminds me of a quote from the movie Princess Bride:
"Miracle Max: OH hu hu, look who knows so much. If he's mostly dead, that means that he's also a little alive... If he's all dead there is only one thing you can do...go through his pockets for loose change"
AkG
AKA Dread Pirate Roberts
Old October 26, 2007, 02:40 PM
Cptn Vortex's Avatar
Awesome movie btw.
The Vortex H20
Asus X99-E WS/USB 3.0
i7-5820K
3 x GTX 1070
4x4GB Corsair LPX 2666MHZ
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
You-Tube Human "Pixels" Perform Live Animation sswilson Off Topic 14 June 29, 2009 08:02 PM
dead mouse ?? fireguy Troubleshooting 7 January 28, 2008 07:28 PM
inches or pixels zaqu Display Units 13 July 6, 2007 10:03 AM
AMD dead ? currently Jim CPU's and Motherboards 14 April 4, 2007 01:28 AM
680i DEAD DEAD DEAD sizerkozak CPU's and Motherboards 29 February 9, 2007 10:08 PM
