Old February 5, 2010, 08:08 PM
BT!'s Avatar
BT! BT! is offline
Default BenQ FP241VW
anyone know why nvidia drivers wont let me change the refresh rate on this monitor? its at 59hz and wont change, i pick 60, it asks if i want to keep settings, click ok, and nothing, still at 59..
Old February 6, 2010, 10:58 AM
Raserei408's Avatar
Odd...but it's 59 vs 60. Does it really make a difference?
"If dancing is sure to result in failure then you must dance anyway."
Lo Mein said that, and I think he knows a little more about dancing than I do pal, because he invented it! Then he perfected it so that no man could best him in the club of honor.
Then he used his prize money to buy two of every whore on Earth. Then he herded them all onto a boat, then they all beat the crap out of every single one of him.
Old February 6, 2010, 11:17 AM
BT!'s Avatar
BT! BT! is offline
no difference, but i think this monitor should be able to do 75hz, but for some reason it wont even let me change it to 60.
Old February 15, 2010, 11:45 AM
There's a trick to doing this, create a manual profile for the monitor. You then get the option of picking the resolution and refresh rate. For the refresh rate, set it to just an edge over 60hz. Something like 60.001 or something; as long as it's the slightest edge, it'll put it at 60hz.
Old February 15, 2010, 12:24 PM
JD JD is offline
Try installing the monitor drivers from BenQ. Might solve things.
Old February 15, 2010, 03:18 PM
It's not the monitor drivers, it's the nvidia drivers that does this. It's a known problem.
[FS] FS: Benq 24" G2400W LCD MarcusFoX Buy/Sell & Trade 20 January 3, 2010 10:31 AM
LG W2252TQ vs BenQ T241W ricknash61 Display Units 2 August 7, 2009 11:09 AM
BenQ E2200HD: Good Monitor? bovine.baron Display Units 7 March 12, 2009 03:19 PM
BenQ FP241VW Tomvill Display Units 4 September 17, 2008 06:18 AM
