Old January 24, 2010, 04:18 AM
Meta|Gear's Avatar
Default DVI to HDMI
Recently purchased an Asus VW246H monitor and i want to check out hdmi, can someone let me know what kind of cable i should be getting, I have seen some HDMI to DVI-D cables for around $12 but I am unsure if that's the right cable.
Is this good enough?
Buy STARTECH.COM LTD [HDMIDVIMM6] Startech 6FT HDMI to DVI-D Digital Video Cable M/M
RFD
Intel i5 2500K @ 4.5 | Corsair H50 | Gigabyte GA-Z68X-UD3H | 8GB G.Skill Sniper 1600Mhz | SLI GTX 460 768MB | Antec High Current Gamer Series 900W
Kingston 64GB V100 - WD Black 500GB - WD Green 1.5TB | CM HAF 922 | Asus VW246H
| Logitech G15 v2 | Logitech G9x
| Steelseries Siberia v2
Old January 24, 2010, 06:46 AM
why not just a DVI to DVI cable?
Old January 24, 2010, 07:52 AM
bojangles's Avatar
That will work. Personally I would buy a DVI-HDMI adapter for the video card and then use an HDMI cable because you can use that HDMI cable else where as well because it has more uses.
Old January 24, 2010, 08:02 AM
Rison's Avatar
You won't actually see a difference going from DVI to HDMI then just DVI to DVI.. unless your monitor is HDMI only? I haven't seen one of those however.
as bojangles said, probably best to use an adapter - especially if you need to lengthen the cable in the future.
I'll learn to manage my anger, when people learn to manage their stupid.
Old January 24, 2010, 08:15 AM
Arinoth's Avatar
Yes that will work as i am using one myself to go from my pc to my tv.
DVI to HDMI no_pulse Video Cards 4 December 21, 2009 06:57 PM
DVI-D to HDMI vs Component rjbarker Display Units 2 August 24, 2009 08:56 PM
DVI-I vs HDMI what shoud I use.... Gameplaywarrior Display Units 5 November 13, 2008 04:55 PM
LF DVI-I to HDMI Adapter earlgrey Buy/Sell & Trade 10 September 7, 2008 02:12 PM
