Old January 15, 2010, 06:35 AM
AmuseMe's Avatar
Default Response Time or 120Hz?
Okay, here is something that I don't quite understand: Which is better for those fast-pace moments? The 2ms reesponse time monitor or the 120Hz monitor?
Old January 15, 2010, 08:40 AM
bojangles's Avatar
I wouldn't worry about response time anymore. Average is around 2-5 ms, which is pretty fast. There's also only one 120 HZ monitor out so far (correct me if I'm wrong here), and it's a 22". Therefore there's plenty of options.
Old January 15, 2010, 12:09 PM
Perineum's Avatar
120hz gives the option of nvidia 3d and should also reduce the effects of 'tearing' that you get with higher than 60fps on a 60hz monitor. Not sure about anything else...
Old January 15, 2010, 12:25 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
120Hz displays will also support 3D Blu Ray.
Old January 15, 2010, 12:32 PM
lowfat's Avatar
Hmm. So will people need top buy new TV's to support 3D blu ray as well?
Mael
Big Lian Li
Forever Alone
Old January 15, 2010, 12:53 PM
120hz for 2d gaming adds for a much smoother more natural like feeling as well as a reduction in ghosting. Acer is coming out with a 24inch 120hz display for gaming. Don't bother with the Samsung 120hz unit since even though it has fast response time, it still suffers input lag.
Old January 15, 2010, 05:44 PM
Perineum's Avatar
Ghosting doesn't seem to be much of an issue on current LCDs, at least not to a point to bother me much. It would be nice to be able to stop using V-Sync, however.
Old January 15, 2010, 07:40 PM
A combination of both is required for the best. As mentioned, response times nowadays are pretty good, for the most part. All you gotta worry about now is the hz and input lag.
Old January 31, 2010, 01:48 PM
Ghosting bothers me on current LCDs. Try turning quickly on an fps and discern details at the same time.
Hardware
-Core i5 750 @ 3.5Ghz (175x20)
-Scythe Zipang 2
-4x2Gb DDR3 (1050@5-5-5-15, 1.65v)
-Gigabyte P55-UD2
-EVGA GTX 260, Corsair 550VX, mATX
Audio/Video
-Samsung LN32A550 32" 1080p LCD
-Asus Xonar Essence STX
-Denon AH-D2000
-Sony STR-DE197 -> Polk Audio M10
Desktop Picture
Old January 31, 2010, 01:59 PM
Arinoth's Avatar
I have no issues with ghosting and i am using the exact same TV as you to game on.
Here I am: here I remain
'No Russian' - An emotional response - MW2 Review mattlef Member Reviews 78 February 1, 2010 12:10 AM
ASUS & NVIDIA Launch G51J First 3D 120HZ Notebook with 3D Vision FiXT Press Releases & Tech News 3 December 7, 2009 03:16 PM
New LCD TV : 60hz or 120hz...? Synth Display Units 10 May 4, 2009 04:47 PM
