Old December 17, 2009, 07:54 PM
Default VGA-DVI Adapter Quality Loss?
I was just wondering if I am using a VGA cable with a VGA-DVI adapter on my video card do I lose any visual quality?
I only have 1 VGA and 1 DVI port on my monitor and one I have connected to my PS3 with a DVI-HDMI cable and the other is a VGA cable with a VGA-DVI adapter going into my video card.
Old December 17, 2009, 09:15 PM
Perineum's Avatar
By using the VGA connector you'll lose some quality, but, since you had to ask, it's obviously not enough to worry about.....
Old December 17, 2009, 09:49 PM
There is no real quality loss. The DVI to VGA adapter is just a passthrough connector which takes the VGA signals being sent through the DVI connector and converts the port into a VGA port.
Old December 17, 2009, 11:18 PM
Perineum's Avatar
Err, I'm wondering now if I read that correctly. Was he referring to the connection style or just the adapter? VGA doesn't give as good a picture as DVI would, but it's not *that* bad, at least what I've seen on lower resolutions (1440x900). I wouldn't expect the adapter to add any significant signal loss or corruption to the mix.
Old December 17, 2009, 11:20 PM
Good point; I assumed he was talking about the latter. I suppose if you combine both our previous posts, it makes up a complete answer.
Quality issue using dvi to hdmi? odis172 HTPC Systems & Software 4 August 5, 2009 04:48 PM
LF DVI-I to HDMI Adapter earlgrey Buy/Sell & Trade 10 September 7, 2008 02:12 PM
DVI and VGA help plz derrXIII Display Units 5 August 10, 2008 05:53 PM
VGA to DVI How much would I notice? TwystedMonkey Off Topic 9 July 19, 2008 10:56 PM
Dvi to Hdmi adapter? cdn_Madrach HTPC Systems & Software 12 October 24, 2007 10:46 AM
