-   Display Units (http://www.hardwarecanucks.com/forum/display-units/)
-   -   Need a new TV, help with recommendations please (http://www.hardwarecanucks.com/forum/display-units/25578-need-new-tv-help-recommendations-please.html)
ragenrok November 16, 2009 09:53 AM
while my current tv is now 5 years old and is starting to fail. Its a projection tv and its starting to get a bad red tint (mainly when dark colours or black screen is present)
For now this tv will work but after christmas I would like to get a new one, im looking for something thats full HD and around 50"-52" and preferably with atleast 2 hdmi ports and mabey even a DVI port, though not as important
Im not very upto date on tv's so im not sure which ones are good for a decent price
KeepSix November 16, 2009 03:56 PM
After Xmas it will be a whole different ballgame. You would be well advised to read the e-reviews now to familiarize yourself with the 'must-have' features and specs, and double-check before you buy later.
I bought a 38" Sharp Aquous 1080 last year around Xmas and it was good bang for the buck. Bravias are decent too. It's all in the eye of ...yeah...
SugarJ November 16, 2009 04:01 PM
My recommendation: TV & Video: Television: Sharp Aquos 52" 1080p 120Hz LCD HDTV** (LC52E77U) | Best Buy Canada Web Store
But you should post a price range that you're looking to spend. It'll help narrow things down. LCD, LED, or Plasma?
Edit: My buddy who troubleshoots HD setups for Shaw says Samsung and Sharp have the best pictures for LCD's, and Pioneer for Plasma's.
grinder November 16, 2009 04:13 PM
if you want the best TV it's no contest. Any salesmen that works at the electronics counter will tell ya the Viera owns (they stare at them all day side by side with other TV brands)
Panasonic 50" Plasma (TCP50U1)
1) Has 3 HDMI inputs (2 rear, 1 side)
2) is 50" (as per your spec of 50 to 52)
3) Plasma has a wider viewing angle than LCD
4) it's a 1080p display
ragenrok November 16, 2009 04:47 PM
lol i wa sjust gonna ask aboutt hat exact tv, looks very nice and people seem to like it.
Im coming from an older crt 1080i projection tv so im sure anything new would look good :bleh:
crazyhorsejohnny November 16, 2009 09:30 PM
Darker room go plasma. Room with more light go LCD.
ragenrok November 16, 2009 09:48 PM
ya i heard that before, theres definatly lots of light in my living room, thanks for the warning :thumb:
lcdguy November 16, 2009 09:49 PM
also if you want a good comparison don't go to bb/fs. Go to a home audio store. here in ottawa thats audiotronic and bleeker. Not sure what you have where you are but i am sure there are some. They will be setup more closely to what you would mostlikely have at home so get the real idea of what it looks like then just buy the hardware from who ever gives you the lowest price.
ragenrok November 27, 2009 09:09 PM
how is this tv? I know its not as new as the other sharp one but its on for a good price ($1200) probably because it sno longer being made.
TV & Video: Flat Panel Televisions (Plasma And LCD): 45 - 54" Panel TV: Sharp 52" AQUOS D65U Series 1080p LCD HDTV | Visions Electronics
lcdguy November 27, 2009 09:35 PM
well i have not heard of many people complaning about aquos's. So it's probably a safe bet. But if it is indeed end of life i would check to make sure it still under warranty and that it's not a refurb unit and what the return policy is should you get a stuck pixel. I would be really steamed if i paid $1200+ for a tv and it had a bad pixel. I know that when i bought my $3k projector if it had one i would be sending it back. That is still a pretty good price for a sharp. Also keep in mind that it has no DVI so if you want to hook a computer to it and get hi-def you will need to use HDMI.
