Old November 13, 2009, 11:02 AM
Default Need help with choosing a monitor
Hey all,
I recently got myself a new computer that I built with the help from people on these boards. That was about 4-5 months ago. I recently realized that I need a new monitor but not sure what to get.
I'd like something that is at least 22 inch or possibly 24. I would think 24 might be to big so I'd like to know what you all think is better to get.
Now I like to play games on my computer so I would guess I need a monitor with 5 or less ms, also I'm not sure if this is possible but is there any monitors that has a display like the new iMacs? my friend recently got one and the color looked really sharp (def a lot better then my current 19 inch monitor)
I don't want to spend to much on a monitor I was thinking no more then $300 canadian (unless there is a monitor that you all recommend thats to good to pass up but costs over 300)
thanks in advance
Old November 13, 2009, 11:20 AM
I'd recommend an IPS type panel. Within your budget, usage, response time, and size criteria, your best option is probably the Dell 2209WA which is a 22" and uses e-ips. It has very low input lag and has fast response time so it suits your usage needs. It's currently on sale for less than $250 shipped from Dell I think. Either way, it's on sale regularly.
Old November 13, 2009, 01:02 PM
how much of a diff is it to go from a 1680 x 1050 resolution to the 1920x1080? I was kinda looking to get a 1920x1080
Old November 13, 2009, 01:16 PM
I guess a better question is will the 1680 x 1050 using e-ips be a lot better then a 1920x1080 using a TN display
I was looking at this one:
DELL G2410 24 inch Wide Green Flat Panel Monitor : Computer Components | Dell Canada
24 inch monitor, 1920x1080 TN panel
Old November 16, 2009, 10:26 AM
anyone have any insight on this? I would use this monitor basically (40% on web browsing/working with text/programming, 50% gaming, 10% watching movies)
Old November 16, 2009, 11:30 AM
CMetaphor's Avatar
Quadfather
If youre not planning on looking at the monitor from odd angles and don't care much for 100%-or-whatever accurate color representation then IMHO you don't need an IPS panel type. A lower response time good quality TN panel will work just fine, and have less ghosting than a PVA or IPS panel as well, since afaik, their best response times are in the 8 to 12ms range (as opposed to 2ms for a good quality TN panel).
Need some help choosing a card.. Dexter Video Cards 13 May 29, 2009 04:44 PM
Need help choosing from some I7 Mobo's quikgp CPU's and Motherboards 3 May 28, 2009 04:51 PM
Need help choosing a motherboard SmogTown New Builds 5 August 17, 2008 09:15 PM
Need help choosing! Kassela CPU's and Motherboards 5 December 20, 2007 02:56 PM
Need help choosing monitor Kessler Display Units 10 July 16, 2007 09:47 PM
