Old October 9, 2009, 10:29 PM
bigjee's Avatar
Default HP 2709m or the Samsung 2243BW - need hlep deciding
Hi,
I need to upgrade from my Samsung 2253LW monitor.
Its a 21.6 inch and fair bit small on my table.
Main uses for my monitor are
1) Gaming (RTS (Company of heroes etc.and the occasional FPS such as left for dead, Bioshock etc.)
2) Watching movies, tv shows that I download.
3) Browsing the internet and reading graphs (FXCM etc.)
4) I will not be connecting any consoles (PS3, Xbox 360 etc) to this display.
I have basically chosen 3 monitors the Samsung XL 2370, Samsung 2243BW or the HP 2709m
I am currently leaning towards the HP since it has the screen real estate and the glossy "pop" effect that I have come to love (I can tolerate glare to a high degree)
I'd like people to pitch in with any good advice that they may have.
Also I've heard that 1920x1200 is better than the 1920 x 1080 resolution that the HP has.
Is that true?
Is the 1920 x 1080 p resolution only good for movies whereas for gaming the 1200 resolution is better?
3rd build:
Intel Q9650 (450*9) 4.05 ghz
/ 1.23Vcore
Noctua NHD14 140mm air cooler
Gigabyte EP45-UD3P Rev. 1.1
4GB G.SKILL PC2-8500 1066 Mhz (5-5-5-15)
Zotac GTX 480
Corsair HX620 modular 620W
Intel X25-m SSD + WD Caviar 640gb + 500 gb
Silverstone TJ-10 B w/ Window
HP 2709M and LNA40a530
Old October 10, 2009, 03:10 PM
Slik's Avatar
Originally Posted by bigjee View Post
Hi,
Is that true?
TheHP is the one. The difference in resolution is mnimal.The price is almost like stealing it.I paid $1600.00 for a 27 inch Dell a couple of years ago. Go figure.
Old October 10, 2009, 07:59 PM
bigjee's Avatar
yeah the Dells are really good displays but way out of my budget.
The HP's are good from what ive heard but the LED backlight of that Samsung is pretty darn good too. Decisions decisions
3rd build:
/ 1.23Vcore
Zotac GTX 480
Need Help deciding PS3 or Xbox 360 AA93 Gaming 39 May 15, 2009 12:47 PM
I need help deciding. encorp CPU's and Motherboards 16 March 13, 2009 12:07 AM
Deciding between 3 sammsung monitors slntdth93 Display Units 2 October 19, 2008 11:12 AM
Need Help in Deciding Swiftech or Thermochill Dashock Water Cooling 3 June 19, 2008 04:15 PM
Deciding on a Case BALISTX Cases 6 May 19, 2007 09:55 AM
