Old September 23, 2009, 09:19 AM
Default Clean LCD
I have a new 24" asus lcd looked great....i had some cleaners come in my home and help me clean,well someone decided to wipe down my 24"& my 40" Sammy...
so now theres smears/greasy smudges all over them
How do i wipe them clean again?
what can i use on them?
Thanks
http://valid.canardpc.com/show_oc.php?id=932179
"Be so good at what you do that you cant be ignored"
Old September 23, 2009, 09:22 AM
gingerbee's Avatar
just water all the time ( my wife owns a cleaning company and she hears nightmares like this all the time ) just use a damp cloth and wipe it clean with a dry piece of paper towel
Old September 23, 2009, 09:25 AM
ok,i will try that..
thanks for the advice
Old September 23, 2009, 09:26 AM
warm water and a micro fibre cloth
Old September 23, 2009, 09:33 AM
micro fiber cloth i wish i had
im 100 miles from a city to far to go...
i will try the welfare way.hehe
warm water ,wipe dry with paper towel/soft cloth
Old September 23, 2009, 09:34 AM
bojangles's Avatar
Gotta ask, is isopropyl alcohol okay too?
Old September 23, 2009, 09:40 AM
umm,i would not try it myself, i'll let other tet iso
Old September 23, 2009, 09:43 AM
Isopropyl is fine. I use it. If it leaves streaks when you're done, just use a paper towel slightly dampened with water to remove the streaks.
Old September 23, 2009, 09:45 AM
for real?
won't hurt screen?
Old September 23, 2009, 09:47 AM
hmm,found a gallon of isagel in me closet...no iso though
Clean your Rads. A lesson Cptn Vortex Water Cooling 23 June 20, 2009 01:44 AM
[FS] Reno's Clean up Sale renoracer Buy/Sell & Trade 1 November 27, 2008 02:14 PM
How Do You Clean Your LCD Monitor? mo' power Display Units 17 November 5, 2007 06:26 PM
Tips to clean radiator eagle_ Water Cooling 2 August 22, 2007 07:28 AM
