Old September 11, 2009, 07:13 AM
bojangles's Avatar
Default Good 24" LCD?
Well, it seems nobody writes review for these things anymore...well, the main consumer ones that we cherish most. I am debating between several monitors, all with their pros and cons. Here is a list:
NCIX.com - Buy Philips Brilliance 240PW9EB 24IN Widescreen LCD Monitor IPs 1920X1200 3000:1DC 5ms VGA DVI-D - MT-PL-240PW9EB In Canada.
NCIX.com - Buy Samsung SyncMaster T240HD 24IN Widescreen LCD Monitor 1920X1200 5ms DVI VGA HDMI Component DTV Tuner - LS24TDNSUV/ZC In Canada.
NCIX.com - Buy Samsung 2443BW-HAS 24IN LCD Black 1920X1200 50000:1 DC 5ms VGA DVI HDCP Pivot Height Adjustable - LS24MYKRBQA/ZC In Canada.
NCIX.com - Buy Samsung 2494HM 24IN Widescreen LCD 1920X1080 16:9 5ms 50000:1DC Vgta DVI-D HDMI HAS W/ Speaker - LS24KIQRBQ/XAC In Canada.
The Philips is on special at random, and while it's an IPS panel, many are having trouble with the half green/half red syndrome on their monitor. I am willing to pay more for this kind of panel, though it has to be at this amazing price (hard to find I know).
Now I like simple. Touch of Colour on the T240HD is alright, but with the desk I have it sits kind of low so HAS is preferable. I would also prefer just a thin matte black panel, unless you can convince me otherwise. HDMI I'm not too sure about as I am on and off about purchasing a PS3 Slim and I don't have a receiver with HDMI .
Then again, if you have any other monitors to recommend give me a shout. Someone wants to buy my 226BW that I've been in love with since I bought it, but it's time to go bigger. Let me know!
Thanks in advance,
bo.
Old September 11, 2009, 07:43 AM
steers's Avatar
I'm using a 2443BW here at work, and it's a pretty great panel, especially considering it's listing for like $350 now. I think that the 2443BW and the T240HD use the same panel, but the matte black casing and HAS make it a bit more appealing in my eyes. I bought a Dell 2408WFP a while ago, and have been drooling all over it ever since, but you'll also end up paying quite a premium for it over just another TN panel. It's a PVA panel as well, so it might just be worth it to get the Philips IPS if you can get a better deal on it.
One site that I can really recommend for monitor comparisons is DigitalVersus, which is affiliated with Tom's Hardware in some way. They have a reasonable amount of data for monitors, and they make it easy to compare specs side by side to help you make a decision.
Balthasar - Loop: EK Multi 150 > MCP655 w/X-Top2 > Feser X-Changer 360 w/3x Panaflo 68cfm (push) > Heatkiller 3.0 > EK-FC275 > EK-FB Classified
Caspar - 2x Xeon E5504 | SuperMicro X8DAi | 12GB DDR3 | Radeon HD4850 | CM ATCS840
Melchior - Rev. A MacBook Pro | 2.0GHz Core Duo | 2GB DDR2 | Radeon X1600
Bob - Core i3 530 | Gigabyte H55N-USB3 | 4GB DDR3 | Corsair H50 w/ TFC Triebwerk | Silverstone SG06
Old September 11, 2009, 01:35 PM
bojangles's Avatar
Well, I pulled the trigger and bought the Philips 240PW9EB. Looks like only a couple people have has the red-green issue. FiXT, did you buy yours?
Old September 13, 2009, 01:54 PM
headsh0t's Avatar
Did you get it at that sweet sale price??? Should serve you well :) Only thing that sucks about it is that it only has 1 DVI and 1 VGA
Old September 13, 2009, 06:30 PM
bojangles's Avatar
Meh. I'm only using the computer with it. The rest is on my TV.
You should also look at NCIX again. They still have an amazing price on it :).
Lots of "DAM" Good deals added this week Gav Hardware Canucks Store 14 August 17, 2009 10:43 AM
Evermount lcd tv/moniter/26"/40" hightest Member Reviews 10 August 3, 2009 01:50 PM
[WTB] LCD Monitor 22 or 24" good panel Malakei Buy/Sell & Trade 4 January 4, 2009 08:32 PM
What's a good 24" LCD? Matt Display Units 4 December 16, 2008 09:39 PM
