Hi everyone,
I need to replace my current workstation monitor--a gigantic CRT--with an LCD equivalent. After painting my room (desert gold!) and having ordered a glass-surface workdesk, I'm honestly not comfortable with placing the 40kg mini-fridge-sized CRT anywhere on it; it won't fit depth-wise either without my mouth against the screen. Here are my preferred criteria:
- high colour/contrast vividness
- very high display resolution: 1920x1200 or greater is preferred: I emphasize on workspace density over diagonal screen size
- excellent colour accuracy
- reasonable grey-to-grey response time; 8ms at most
- a fairly wide viewing angle
- 125-watt maximum power draw
- a bezel thickness no greater than 2cm
- no need for DisplayPort unless it is cost-effective for expanding the workspace onto more displays; DVI will be fine otherwise
- fancy inputs and swivels are not necessary; BNC input support is a plus, but not required
My budget is about CAD$700, somewhat flexible, and I'd like to keep the recommendations within the 24-inch display size region to avoid space-high prices. I realize my long-decrepit 9600 SE will not take resolutions greater than the current 2048x1536, but I'll soon brick it for a pair of basic FireGL's later down the road.
So far, I've found that the
Hewlett-Packard LP2465 (
Home;
Cnet) fits the bill quite comfortably. Again, I'm open to all suggestions.
Kind regards,
Dan
