Old August 27, 2009, 09:23 PM
ToXic's Avatar
Default Aproximated burn in times?
so i have a LG LCD tv and im wondering what my approximate burn in time on a still image would be like so i know if its a good idea to turn my tv off when idling for a wile (i dont let my computer sleep that often...)
I'm back, baby.
XPS 9560
Old August 27, 2009, 09:34 PM
hightest's Avatar
Lcd does'nt need burn in time,only plazma's and it's about 200 hr's burn in time on a plazma,but u shood have a screensaver set i think i allway's do that
Man all this computor stuff is 2 addicting.Even thou i dont need 2 i allways wanna upgrade.
Old August 27, 2009, 10:02 PM
Arinoth's Avatar
If i'm not using my computer even if its folding or doing something, i just turn the monitor off, save power
Here I am: here I remain
Old August 27, 2009, 10:03 PM
Jake_HT's Avatar
too easy
http://jakeht.deviantart.com/
Old August 27, 2009, 10:22 PM
ToXic's Avatar
well i have burnt in a 20.5 inch monitor before... it had my wallpaper cooked in because of vista malfunctions.
I'm back, baby.
XPS 9560
Old August 27, 2009, 11:25 PM
Unknownm's Avatar
I never heard of a LCD burn-in. LCD's can have pixel glitches where so many pixels are glitched or stuck. I heard plasma's can get burn-in in 20-30 minutes.
My CRT has a burn-in it's hard to tell but you can see it still
Old August 28, 2009, 04:32 AM
Gellidius's Avatar
plasmas don't and can't get burn-in in 20 mins;
but they can get IR (image retention) in that amount of time;
but usually after about 5 mins or so with a static image on the screen, the tv goes in standby mode (black screen) to protect it.
There are simple remedies to get rid of IR, but none for burn-in.
Jacques
Ego cogito, ergo deus non est.
Old August 28, 2009, 06:03 AM
gingerbee's Avatar
i have lcd's literally every room never have i seen or heard of this
Old September 1, 2009, 09:39 AM
JimboToronto's Avatar
I always thought lack of burn-in was one of the selling points of LCDs.
Old September 1, 2009, 09:48 AM
Sagath's Avatar
Agree. I'm not a LCD techwiz, I do know enough about basic Electronics to get by. Normally transistors (which is what makes a LCD work at its fundamentals) are either on or off. Either you're applying enough voltage to gate them, or you're not. Hell, without a back light, you can barely tell if a LCD is on. Some laptops can show you this if they have the ability to set the brightness to zero (which may not turn the backlight 'off'). Or to turn the backlight off, like on my Asus.
I dont see how it would be possible to leave a residual image even with a back light on. Unless, as was mentioned by another poster, the transistor got 'stuck' on.
Intel Burn Test 1.92 Any Good? Yamcha Overclocking, Tweaking and Benchmarking 16 May 16, 2009 09:31 AM
Testing Intel Burn Test 64 and Prime 95 64 (Help?) appplejack Overclocking, Tweaking and Benchmarking 1 January 11, 2009 04:53 PM
could i burn out my mobo by....? andynerd CPU's and Motherboards 9 December 28, 2008 10:29 PM
Burn time enzeo Storage 3 July 24, 2007 11:13 PM
CPU Burn-in time Bognostraglum Troubleshooting 7 April 28, 2007 08:25 AM
