Old August 27, 2009, 01:26 PM
Nodscene's Avatar
Default Need advice from TV experts.
I currently have a Samsung 50" DLP tv that I'm looking to upgrade. I don't really care if it's LCD or Plasma. I'm looking to get something around 58" that has HDMI 1.3, THX, and at least 120hz. I'd also rather not break the bank.....basically the best bang for you buck. I was thinking about the new LG 60" 60PS11 (around $2499)but it doesn't get the best reviews. At least it's in my price range though. Alternately the is the LG 60PG60 that although it's a year old has some great features and can be found for a good price here.. Home
What does everyone recommend? I'd definitely like to keep it for a number of years. I just bought the new Oppo BDP-83 and would like to match it up with something that can take advantage of it.
Thanks
Create something idiot proof and they will make a better idiot.
_____________________________________
Intel Q6600 - Gigabyte EP35-DS4 - OCZ Reaper 4gig PC2-6400 - XFX 8800GT 512Mb Alpha Dog - AuzenTech X-Fi Prelude - Alesis M1Active MK2 - Corsair HX-620 - Silverstone Temjin TJ05B-X - Scythe Katana 2 - WD Raptor 150Gb - Seagate 7200.11 750Gb x2 - Samsung SH-S203N
Old August 27, 2009, 01:34 PM
If it's going in a room with lots of light get lcd, darker room go plasma.
Old August 27, 2009, 01:44 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
In my experience, LCD screens above 55" are usually of poor quality.
If I were you, I would seriously look at the Samusng LN55B640. It is a great set with a ton of connectivity and sports most of the features the slightly higher-end LN55B650 sports. The contrast is also one of the best on the market right now. So much so that it beats the pants off the new XBRs in my opinion.
If you are willing to go with a slightly smaller screen, I would go for the Samsung LN52B750. Many regard it as one of the best sub-$3500 TVs on the market today.
Old August 27, 2009, 03:01 PM
Nodscene's Avatar
Thanks Skymtl, I'll definitely take that under consideration. It's a tad smaller than I wanted to go, mostly because I need as much justification as I can muster for buying a new tv :) I can't see to find out whether it's HDMI 1.3 or not, do you know for sure?
Crazyhorsejohnny, I try to have my room as dark as possible so that's why I was thinking of going Plasma but not dead set on it.
Thanks
Old August 27, 2009, 08:47 PM
hightest's Avatar
I think if your room is dark go with a samsung lcd, they have the glass in frunt of there panel which makes the picture more vibrant i think.
But since your not gamin on it the plazma's are much cheaper,but they use twice the power of an lcd, and give off alot more heat.
When i bought all our lcd's i went and looked at them alot and did lots of pro's/con's of what i needed in our lcd's.
Man all this computor stuff is 2 addicting.Even thou i dont need 2 i allways wanna upgrade.
So... I might want to go back to school. Any machinsts / aviation experts here? S_G Off Topic 25 January 29, 2009 01:20 AM
Here's one for the RAM experts... dadzilla RAM 8 November 24, 2008 07:59 PM
Hi I need your advice/help blogz101 New Builds 4 July 7, 2008 08:20 PM
In need of advice doup93 Video Cards 6 March 17, 2008 05:40 PM
need advice Rapid-X CPU's and Motherboards 7 January 30, 2008 04:15 PM
