Old August 10, 2007, 11:06 PM
Default How Do You Clean Your LCD Monitor?
I was wondering how you clean your LCD monitor. I happen to be a smoker, so the standard water and soft cloth won't cut it.
Old August 10, 2007, 11:14 PM
you clean a lcd monitor? hmm odd never have.
Old August 10, 2007, 11:53 PM
Supergrover's Avatar
I use monitor cleaner.
R.I.P.
Old August 10, 2007, 11:57 PM
I use LCD clean screening fluid and a microfiber cloth at work ...
Old August 11, 2007, 06:32 AM
omgwtf's Avatar
spit + tissue works for me.
Memento mori
Old August 11, 2007, 07:47 AM
Moneyless's Avatar
Gross.
"I hate broccoli
And think it totally sucks
Why is it not meat?"
-Deadpool
Old August 11, 2007, 08:24 AM
Robscix's Avatar
I bought a small kit from Belkin that has a bottle of fluid and a Brush with replaceable cloths. You would be surprised how much dirt you see after a good cleaning
Old August 11, 2007, 12:01 PM
JD JD is online now
Not supposed to put your greasy hands on the monitor
I just use a micro-fiber cloth. Use water if you need to clean it. No sense in spending money on those "cleaning" kits I'd say.
Old August 12, 2007, 10:01 AM
Robscix's Avatar
The kits are cheap. I bought one so I could get the cloths and the brush.
Old August 12, 2007, 10:13 AM
Patriote's Avatar
Soft cloth and water ... Is only thing i would use on an LCD monitor.
- Asus P8Z68-V PRO
- Intel I5 2500k @ 4.5Ghz
- Asus Geforce 580GTX DirectCUII Fermi
- 16GB Corsair Vengeance Low Profile
- Ultra X3 1000 Watt
- Asus Xonar DX 7.1 \ Klipsch Promedia 2.1 THX
- Corsair Vengeance 1300 Gaming Headset
- Crucial M4 SSD 128GB \ WD Caviar Black 1TB
- CoolerMaster 690II Advanced
- Dell UltraSharp 24''
- Noctua NH-D14
LCD Monitor or LCD TV Brando737 Display Units 5 February 13, 2008 02:51 PM
Looking for new monitor kojicolnair Display Units 4 December 31, 2007 09:03 PM
Useing Water to Clean PCB's? Supergrover Off Topic 9 October 23, 2007 01:31 AM
Tips to clean radiator eagle_ Water Cooling 2 August 22, 2007 07:28 AM
tv or monitor ? Jim Display Units 2 April 14, 2007 01:42 AM
