Old August 24, 2009, 11:30 AM
rjbarker's Avatar
Default DVI-D to HDMI vs Component
So, picked up a 40" toshiba Flatscreen and a Shaw HD (non PVR) Cable Box yesterday for our bedroom.
I was somewhat surprised to realize no HDMI "out" on the Cable box, only DVI-D.
So, question is, any picture quality difference using DVI-D to HDMI cable vs Component Cable?
the HD Cable Box is only capable of 1080 interlace (vs 1080 Progressive Scan) and reflects this with the Component Cable utilized.
I did purchase a DVI-D to HDMI Cable for cheap ($35), but thinking of returning it. Note, if I use the DVI-D to HDMI cable, i have to pick-up an Audio Left / right output to single input....seems odd, but the Toshiba TV only has a single input Audio jack that is on the same "line" as either the HDMI #1 input and PC input.
Cheers
Firestrike Extreme: 21.452
MARK 11: 32.530
Old August 24, 2009, 11:56 AM
Nodscene's Avatar
Both Component and HDMI do 1080p. So you won't notice any video quality difference.
Create something idiot proof and they will make a better idiot.
_____________________________________
Intel Q6600 - Gigabyte EP35-DS4 - OCZ Reaper 4gig PC2-6400 - XFX 8800GT 512Mb Alpha Dog - AuzenTech X-Fi Prelude - Alesis M1Active MK2 - Corsair HX-620 - Silverstone Temjin TJ05B-X - Scythe Katana 2 - WD Raptor 150Gb - Seagate 7200.11 750Gb x2 - Samsung SH-S203N
Old August 24, 2009, 08:56 PM
JD JD is offline
Yeah no point, especially when its only 1080i max.
Only reason I used HDMI on my cable box was because it was a native HDMI port so it does sound too, thus less cabling. Can't say I noticed any quality difference though.
HTPC Environment DVI->HDMI Issue pdjmwj Video Cards 5 August 13, 2009 05:25 PM
Quality issue using dvi to hdmi? odis172 HTPC Systems & Software 4 August 5, 2009 04:48 PM
DVI-I vs HDMI what shoud I use.... Gameplaywarrior Display Units 5 November 13, 2008 05:55 PM
LF DVI-I to HDMI Adapter earlgrey Buy/Sell & Trade 10 September 7, 2008 02:12 PM
Dvi to Hdmi adapter? cdn_Madrach HTPC Systems & Software 12 October 24, 2007 10:46 AM
